3.5 bottom end with 3.0 heads and jwt cams in and running!
This morning i pulled the ole 3.0 after dynoing last week for baseline numbers. I then swapped all the sensors and intake manifold onto my 3.5 bottom end with 3.0 heads (vq30det) and jwt cams, obx headers, light weight flywheel, udp(on car prior too swap) and exhaust(on car prior too swap). well turnout is awesome it is very fast need to do some tuning though but will at least have 1/4 mile times soon.
you have a vq35de block and vq30det cams? in a fourth gen..wow..
so this is like the honda kids "ls-VTEC" the LS block with vtec cams?.. must have been an insane project.. nice work.. pics please.
Tilleys99,
Were any mod's needed for the heads to fit correctly. Is the cylinder bore of the VQ35 block the same diameter as the VQ30? If not, how were you able to accomodate for the squish in the combustion chamber. I'm assuming the area on the VQ30 heads were either close enough or you had to open up the chamber on the heads slightly. Or were they just a perfect match? What CR do you think this combination is producing? Anyways, congrats on the project I'm glad to see another person on here doing some imaginative things.
Another question I have is about the timing. Were there any issues getting the crank & the cam's to line up properly & did you have to modifiy the timing chain set up at all. I'm assuming the tentioner must of had enough adjustment to take up or allow for any slack?
Oh i forgot to say i put this in my girls car! but my car will be done in the next week probably. The DET heads supposedly have better springs so I threw them in, the cams are JWT. Last night I was holding in 2nd while my buddy in his 300zx (90) NA with some mods was in 1st then 2nd then third and he still couldnt pull ahead of me
obx headers suck you need to cut the brackets on the motor that go to the mount. No race fuel needed and no problems yet but I am installing a a/f gauge today just to see if its running proper.
im tilleys gf, just wanted to say that i am very excited about my max.... now i def need to sell my accord..... the max is enough reason for me to change my previous view that since i wasnt drivin a civic, hondas were ok....yeah, theyre all junk
Thats what IM talking about..
Originally Posted by TILLEYS99
normal 3.0 heads would be fine just put them in cause my car will be using ported 3.5 heads and I have like 3 or 4 sets of 3.0 usdm heads sitting around
So what parts from the 3.5 exactly did you use? I'd probably never actually do this, but it is something to think about. I can't get over how cool this is. Any idea on what kind of improvement this has given just from a butt dyno point of view?
good job Rob.
