Several questions on going turbo!!
Old Sep 6, 2004 | 11:36 AM
1BADMAX's Avatar
Alright, I'm trying to find out how many of you, if any have had major problems with your engine due to turboing your Maxima's. I'm currently away from the states making a pretty good amount of money and when I return I'll have no bills at all.....thank god. Anyway, I'm looking at going one of 2 ways. First, do all the bolt-on's including, lightned flywheel, lsd, cams, and then also change some of my parts out for better versions. I.E. the headers will go from Stillen to Hotshot and the exhaust from Stillen to Cattman full cat-back. The second option was to go turbo and also put some better pistons, rings and also get a tranny rebuild from Level 10. Now, on the turbo; are the pistons, rings, and tranny rebuild neccesary or over kill. Plus, obviuosly the more strain you put on an engine the shorter the life span of the engine will be, but of turboing and going with full bolt-ons which would be worse. Anyway, I appreciate any help you can all give. Thanks.
Old Sep 6, 2004 | 02:22 PM
densetsu's Avatar
it depends how much boost you plan on running. i think you should do some research because this is probably going to get locked...
Old Sep 7, 2004 | 02:44 AM
1BADMAX's Avatar
Ok, I tried to search this before, but I keep getting this message. So, please somebody help a fellow Maxima owner. Thanks.
Fatal error: Allowed memory size of 8388608 bytes exhausted at (null):0 (tried to allocate 129 bytes) in /home/httpd/vhosts/forums.maxima.org/httpdocs/search.php on line 835
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
09maxshawn11
Sep 30, 2015 10:28 AM
