Hacked STS --> PICS Inside!
hey guys,
i decided to hack a few inchs off my sts. Can out pretty nice i think. I need to order some redline mt 90 becuase i dont think mine has every been changed. Its a tad notchier but with the mt 90 i think it should be a lot smoother.
Let me know what you guys think.
Sean
Sean
well it was an ebay shifter. I had to cut it that short or about 2 inchs higher. There was a metal lip on the shifter that i had to cut below or about 2 inchs about so my shift **** would fit on. I do have long arms so its not a prob
Actually, you must be kind of short, because tall people (like me) have to sit far enough back from the steering wheel( because of long legs) that even with long arms, I would have a hard time reaching that with comfort.
I think it is too short for the application of the Maxima.
I mean, in a Corvette, it fits, but you are laying down, and the shifter is right by your arm. In other sports cars, it is the same way. The Maxima just sits up too straight, because it is a sedan, for this to be that good.
It does look pretty good though.
u really dont have a hard time using it. The e brake is sorta in the way but it doesnt bother me. I like the way it looks. Check out Affarios
heres a link to his homepage: http://www.cardomain.com/memberpage/212763
The only problem is when its cold its hairy getting it in 1st.
Way to short for me and Im 6' 1" and I have aftermarket seats which put you a little lower anyway. And I have the sts and with it at about 25% away from being all the way down and to the shortest possible setting. Its kinda short so for me I would say there is no way I would do this. Can you actually drive like that. Is it hard to shift. Good luck with that. I see you getting annoyed with that in a month and then having to buy a new sts.
Bruce
Bruce
mine sits alittle higher then yours, just a hair or two, the shift **** i have in the picture is decieving. i actually have a ball type now and its only a 1/4-1/2 inch higher then yours, i switched to a counterweighted shift ****. makes shifting smooth as butter. nice work, i know that notch does get in the way huh?
p.s.- my e-brake doesnt get in the way because i drive with it up...
NO it does look good matter of fact I think it would be that hard to drive but I know how my sts feels and the shorter I make it the harder and notchy it gets but then again you didnt adjust it you just cut it down so I guess it might not be as bad as I think but it does look cool.
Bruce
Bruce
Originally Posted by DAVE Sz
who in the world is Affario? Next time you want to compare something to someone else's make sure to get their name right.
thanks everyone for your comments.
Originally Posted by papasmurf
What brand do you have, I havent looked at mine in three years. I have the Pacesetter STS. If this is the same one you have then Im going to have to make mine this short too huh
Bruce
Bruce
Originally Posted by sean05
i think mine is a pacesetter knock off. It was like 40$ off ebay. My dad bought if for me.
Bruce
Oh ok I'll have to look at mine and see if I have the little bump or not cause I dont think I need more than a inch or two. Thanks thats great.
Bruce
Bruce
The little bump is actually a lip that goes around the shifter to hold the boot up. That lip, if needed to be, can be either grinded or filed down. No biggie.
I agree its too short. I have a Pacesetter at its lowest/shortest setting. Any lower is too low. But if you like it........
Bruce
HA HA u got a stub!
