What makes the brake booster not work properly?
I have a 95 Maxima and recently had a brake job. The pedal makes a weird noise when it goes to the ground, like I'm touching metal. When the air conditioning is on I have a hard time stopping. The car has even skidded a couple of times. I took it back to the dealer and they said that I needed injectors and ignition coils to make the brake booster work at normal specs. Is this true? They didn't tell me that before the brake job and knew about the injectors and coils.
you need a leak free brake booster for starters, second brakes work on vacum so why on earth would they tell you that u need ingnition coils and injectors workin good, go where u had ur brakes dont and ***** at them.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
