MTM pics 56knotagoodidea
Originally Posted by Y2KSESteve
Is this diff from the DTM in that the side reflectors are black? Looks good.
Well sorta....I left the corner reflectors out...same for when I had red/clears
Originally Posted by CarbonDreams95
i like it, so then you had to put them in the oven to get the lens off?
i'm afraid if i try that with my luck i'd melt ehm
Once I put in the cut fluorescent plastic the clear lens showed how jagged the edges were and so I put it all back to the original shape. While trying to press the lens back on I cracked the corner.
Now it looks fugly when viewed close up.
see thats exactly what i don't want to happen, i might go for it anyways though, thx for the input blackcat
It isn't difficult to do if you take your time. I messed up the first set I've ever done, but I have 4 perfect sets in a row since then. Just practice on something like a stock bumper light.
yes but see the problem is that i only have one set, there is no room to screw up
I cracked one of mine when I was putting them back together. I put too much pressure on the lenses when I put them back together. I also cracked one by using tools to try and pull them apart. Heat and gloves are the way to go with pulling them apart.
[QUOTE=Y2KSESteve]I cracked one of mine when I was putting them back together. I put too much pressure on the lenses when I put them back together. QUOTE]
There's a tiny lip on the lens. When I tried to push it in so that the two halves meet up I cracked it along the corner by the red reflector. The glue was hardening up and very hard to manipulate.
so i heat them a 200degrees for 10 min, take ehm apart, tape, then spray,then wait, then spray,then wait, then i have to heat ehm back up again to warm the glue up, then put them back together carefully? or am i missing something?
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
