Sponsored by:
Sponsored by: CARiD
8000 - 9000 rpm VQ30DE valve train.
Old Oct 21, 2004 | 12:15 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
Is there any aftermarket parts besides the jwt cams that can make this as safe as possible I read a post about using titanium 2jz retainers and springs. Lets clarify this now. what are the best valve stems, springs, retainers, and cams for a 8,000 - 9,000 rpm VQ30DE?
Old Oct 21, 2004 | 12:26 PM
Jeff92se's Avatar
I'm needing a caw
Cams only open/close the valves. They don't do anything to make the engine any safer to rev. Valvetrain items like stronger springs might help prevent valvefloat. Lightweight valvetrain items might will reduce the amount of mass the engine has to overcome.
But you are ignoring the entire lower end of the engine. If you REALLY want to get into the 9,000 rpm range. You had better tear the entire engine down, get the block magnafluxed and maybe alignbored. Get the crank checked and balanced to a tighter tolerance. Get stronger rods and maybe pistons. Also invest in quality bolt hardware. Once you have all the parts, you're going to have all the rotating parts balanced and assembled at once. ie.. shortblock/flywheel/clutch and maybe the crankpulley etc....
I'm not even sure there is enough aftermarket stuff out there that would allow the VQ30 to even make any power at 9,000 rpm. You can rev the stock engine to 9,000 I guess. But making it last for any reasonable amount of time is the trick.
Old Oct 21, 2004 | 12:33 PM
Tatanko's Avatar
Bacon Lover
Yeah, even with a VI of some sort, I can't see revving to 9,000 being beneficial at all. I just think the power would drop off before that. Krismax has gone to 8,000, but I don't think he ever did a dyno to see what kind of power it was making up there, did he?
Old Oct 21, 2004 | 01:02 PM
pawnstar12's Avatar
if not 9000 rpm 8,000 is fine. im doing a DEK IM swap and i have forged pistons and the block will be balanced and checked. i know im pushing the stock rods .....(and so what) they can hold what ever hal is doing to them. im gonna do this engine right, belive me. I just want to know if there are titanium components that we can use for 4th gen heads.
Old Oct 21, 2004 | 01:03 PM
Jeff92se's Avatar
I'm needing a caw
Um VI won't make the difference. You need to consider valve size, port size, cam profile, yes intake manifold design, TB size, maf size etc.....
Old Oct 21, 2004 | 01:06 PM
pawnstar12's Avatar
q45 tb
im gonna use a map sensor set up
ported and polished heads
Old Oct 21, 2004 | 01:10 PM
Jeff92se's Avatar
I'm needing a caw
I think recipocating stresses are different than stresses from boost. So if hal is getting 500hp out his motor from boost, doesn't mean you can spin the engine to xxxx rpm to get 500hp to match.
Old Oct 21, 2004 | 01:12 PM
pawnstar12's Avatar
hmmmm gonna look into that
Old Oct 21, 2004 | 01:26 PM
Stephen Max's Avatar
That's right. In fact, boost pressure helps to lower rod and rod bolt stresses since it acts against the tensile load seen by the rods at TDC when they are reversing direction.
Old Oct 21, 2004 | 01:37 PM
Tatanko's Avatar
Bacon Lover
I know, I'm just saying that if he were to be on the USDM manifold, for example, it would be even worse since it has poor top end to begin with. I know all about needing better airflow in all the areas of the intake.
Old Oct 21, 2004 | 03:32 PM
Nealoc187's Avatar
SLOW
Except when you let off the gas at 9000rpm, then you don't have nearly as much cylinder pressure pressing "down" on the reciprocating components when they are moving up and you run the risk of stretching a rod or rod bolt...
Mass is the enemy of high rpm operation. Lighter components in both the valvetrain and the bottom end are necessary.
Old Oct 21, 2004 | 03:42 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
With boost you don't need/use 9000rpm Neal.
Comparing a NA engine at 9000rpm vs. a boosted engine at 7000rpm producing the same output, the tensile stress exceeds the power/compressive stress of boost by SEVERAL multiples.
Old Oct 21, 2004 | 04:13 PM
krismax's Avatar
Father of the 00 VI
I dont believe our oil pumps can take high rpm ,so make sure you swap a better one
Old Oct 21, 2004 | 04:20 PM
Nealoc187's Avatar
SLOW
I didn't say you would or should. I was responding to what stephen max said about the extra cylinder pressure counteracting the tensile stress on the rods and rod bolts on a boosted engine running those kinds of revs, which is true until one lets off the gas like at the end of a 1/4 mile run.
Old Oct 21, 2004 | 04:26 PM
IceY2K1's Avatar
And I'm saying that StephenMax wasn't comparing a boosted engine at 9000rpm, but a NA engine at 9000rpm and a boosted engine at stock/slightly raised rev-limit.
I know the quote he's referring too in Corky Bells' "Maximum Boost". It's a ratio of like 20%(boost) vs. 120%(1200rpm more) IIRC.
Old Oct 21, 2004 | 04:29 PM
krismax's Avatar
Father of the 00 VI
I vq 3.0 with lighter valvetrain and upgraded oil pump will rev to 8000rpm with no problems.
Make sure to check your oil
Old Oct 21, 2004 | 04:51 PM
Nealoc187's Avatar
SLOW
I must have totally misunderstood him then because I thought that was what he was saying.
Old Oct 21, 2004 | 05:01 PM
IceY2K1's Avatar
Jeff and SM both said boost *VS* over-reving aren't apples-to-apples rod stress wise when looking at the same output level. SM just clarified why.
I agree on your point though...I'm glad you said it, since I hadn't considered it. Although, I wouldn't push over 7000rpm *IF* boosted, so it's not a concern.
Old Oct 21, 2004 | 05:09 PM
IceY2K1's Avatar
However, now that I think about it more, if you "let off the gas" by shifting or whatever, you unload the engine.
So, is rod stress a concern still?
Old Oct 21, 2004 | 05:15 PM
Nealoc187's Avatar
SLOW
In that case yes I agree the stresses on the internals are not in any way the same when comparing a 7000rpm high HP engine vs a 9000rpm high revving engine. Tensile stress vs compression stress. I must have just misread somewhere in this thread because I'm at work right now trying to post on here and listen to these idiots I have to call on the phone.
Old Oct 21, 2004 | 05:23 PM
Nealoc187's Avatar
SLOW
In the high revving situation, the stress I'm referring to is the the "stretching" stress that is put on the rod as the rod has to deal with the mass of the piston moving up at such a high rate of speed, sortof like a rubber band stretching. Such a stress shouldn't be subject to engine load. Regardless of whether or not the engine is under load or not, the piston and rod are moving at a fixed speed at any given RPM and the rod has to "hold on" to the piston.
Old Oct 21, 2004 | 09:36 PM
SR20DEN's Avatar
VQ Wizard
It usually isn't the rods that are first to fail during an over rev. The rod bolts are more or less the fuses in this case. The VQ35 rod bolts only allow for a constant 7200rpm wheras the Nismo rod bolts allow for 7500+.
The valvetrain can be made to handle a 4500rpm cam speed but that will get costly. I have mentioned in other threads before that the VK45 Ti valves will work in the VQ30 heads but the lenghts are a little shorter and will require different shims (on top of the lifters). You can also switch to Ti retainers but the mass savings is so minute it isn't even worth the cost. The most important part of this valvetrain would be the valve springs. Something with about 150 lbs. @ 27.8mm (stock is about 100 lbs. @ 27.8mm)should do the trick but that extra valvetrain load is going to hurt your low end torque.
Old Oct 22, 2004 | 11:01 AM
pawnstar12's Avatar
tnx sr20den.
Old Oct 22, 2004 | 11:05 AM
pawnstar12's Avatar
i guess i should read that book since i have it. im still trying to take in jeff hartmans, how to tune and modify ems
Old Oct 22, 2004 | 11:47 AM
IceY2K1's Avatar
Yeah, I'm jumping around in Jeff Hartmans', it gets boring if I don't.
I've pretty much read all Corkey Bells' except the carb and some other stuff I didn't care about. Easy and worthwhile read.
Old Oct 22, 2004 | 11:53 AM
pawnstar12's Avatar
reading jeffs book is worst than drinking a bottle of nyquil
Old Oct 22, 2004 | 11:54 AM
IceY2K1's Avatar
LOL!
That's what I read to put me to sleep at night. It's on my nightstand. Haha.
Old Nov 4, 2004 | 03:30 AM
pawnstar12's Avatar
hey what is the part # for the nismo rod bolts because i went to the nissan dealer and they said they dont make them for the VQ30
Old Nov 4, 2004 | 05:22 AM
stephenlc's Avatar
call arp. I don't see the point of being boosted and reving to 9000 rpm when the VQ has a hearty enough power band.
9000 rpm for a n/a setup wouldn't be bad. You would need individual throttlebodies and a ligtened valvetrain and a balanced upgraded lower end. Like nissanperformancemag.com 350z guy with the VQ30 and vustom transmission in his car that revs to 8500 rpm or higher.
Old Nov 4, 2004 | 05:32 AM
SR20DEN's Avatar
VQ Wizard
They don't.
Old Nov 4, 2004 | 07:28 AM
ChromeSE5's Avatar
okay, im not engine PRO with the vq30 or any othe rengine, but after reading this i am curious to know what would prolly be the maxima rpm the vq30de-k would make horsepower before it dropped. I ask this because of the technosquare ECu which raises the revlimiter to 7100 rpms. Is the increased limiter enough to take full advantage or could our engiens go even further than that and make more power (say 7500 rpm or even 8000 rpm). Or has this pretty much not proven (lack of dynos or what not)
Eugene.
Old Nov 4, 2004 | 08:11 AM
IceY2K1's Avatar
We don't know yet, however with just a POP charger, I'd say around 6600rpm it starts falling but not like a brick.
Old Nov 4, 2004 | 03:45 PM
Larrio's Avatar
The Definitive AE Master
it gets to a certain point where higher rpm hp requires good breathability with the intake manifold
Old Nov 4, 2004 | 03:59 PM
IceY2K1's Avatar
I doubt that's our DEKs first hurdle...cams are.
Old Nov 4, 2004 | 04:11 PM
Larrio's Avatar
our manifolds IMO do not perform as well as the 2k2+ manifolds or custom manifolds. Especially with the plastic power valve design with the VIAS
Old Nov 4, 2004 | 04:19 PM
IceY2K1's Avatar
I'd agree, since VQ35s are moving a lot more air, however the first wall/limit will be our cams not heads/valves.
Slap on a set of VQ35 heads/intake manifold/Tomei cams/TC and call it a day IMO.
Old Nov 4, 2004 | 04:31 PM
Larrio's Avatar
doesn't the vq35 heads on the 3.0 block supposedly lower compression? So you'll need custom high comp pistons to go NA?
my brain isn't working right now, whats TC?
Old Nov 4, 2004 | 07:53 PM
stephenlc's Avatar
yah it does lower compression. and TC is the ecu I guess?
Old Nov 5, 2004 | 09:50 AM
JeffesonM's Avatar
living out of a maxima...
torque converter?
Old Nov 5, 2004 | 11:20 AM
IceY2K1's Avatar
TopElement....
