best way to polish valve covers?
Old Oct 21, 2004 | 08:18 PM
Tonyklem's Avatar
whats the best and or easiest way to do it.
thanks
Old Oct 21, 2004 | 09:43 PM
HTPerformance's Avatar
elbow grease
Brian
Old Oct 22, 2004 | 12:00 AM
Maximan190's Avatar
and lots of sand paper/buffing/polishing... it took me a few weeks of on and off work to sand/polish/paint a good handful of brackets/clips around the engine bay
if you have a wire wheeler thats a good start
Old Oct 22, 2004 | 12:13 AM
MrGone's Avatar
pawn it off on some unsuspecting sap
Old Oct 22, 2004 | 05:14 AM
Tonyklem's Avatar
what if i wanted just a brushed finish. would a wire wheel do the job and be done? or do i need clear coat? anyone know of any writeups or anything?
Old Oct 22, 2004 | 06:14 AM
shvelle's Avatar
http://www.caswellplating.com/buffs/buffman.htm
Old Oct 23, 2004 | 10:56 AM
pezking4's Avatar
I did mine by hand and it took a very long time and I'm probably going to go back and improve it now that I know more about what I'm doing.
Pics on my cardomain page.
I'm currently working on a project for my 328, painting the center of the wheels black and polishing the lip. I put the wheels in a parts washer machine for a total of about two hours to get rid of all the brake dust, road debris, etc. Then I painted on some metal stripper and then scrubbed the clear coat/paint/primer off with a brush. Some of the paint still won't come off (damn BMW paint!) so I'm going over the lip with a metal brush bit and air tools. Then I'm going to polish with 400, 800, and 1500 wet sanding. Then you just finish the job off with rubbing/polishing compound and its a good idea to put sort of sealant on the metal since it is now exposed to the elements without paint to protect it.
Old Oct 23, 2004 | 11:07 PM
Tonyklem's Avatar
gee, thanks pez ive been working with a wire wheel bit to get all the.. i dont kno what it is, the stuff that they put on it to kind of give it a texture... off, thenn i was gonna use sand paper similar to what u are going to use to finish it off then put some clear coat on. How many coats of clearcoat u think i should use?
Old Oct 23, 2004 | 11:13 PM
MrGone's Avatar
i dont think they put anything on it to give it texture, instead it is a cast peice and is a result of the casting process.
Old Oct 25, 2004 | 08:15 AM
DanNY's Avatar
Ad·min·is·tra·tor
thanks
best and easiest way...
send it out and have someone else do the work.
Old Oct 25, 2004 | 08:19 AM
Matt93SE's Avatar
STFU n00b!
What Dan said.. if you don't know what you're doing, it's worth the $ to just send it off and have it done. In the time you'd spend on it, you can work at minimum wage and make more money than it would cost to have it done in short time by a professional.
Old Oct 25, 2004 | 09:20 AM
pezking4's Avatar
Yeah, I forgot to mention that. You better be the type of person whou just gets bored and likes to do projects that take a lot of time because you don't want to get in the middle of it and get tired of working.
The right equipment makes a huge difference.
Old Oct 25, 2004 | 09:49 AM
Jeff92se's Avatar
I'm needing a caw
Then how come the rear valve covers don't have the same texture??
Old Oct 25, 2004 | 10:42 AM
icepick's Avatar
2 diff. types of cast !!! as far as i noticed
Old Oct 25, 2004 | 10:44 AM
Jeff92se's Avatar
I'm needing a caw
In all honestly, it looks like the front cover was cast then sand blasted, coated.
Old Oct 25, 2004 | 11:44 AM
Tonyklem's Avatar
anyone know of a good place to send it to? thanks for the info guys
Old Oct 25, 2004 | 12:31 PM
DanNY's Avatar
Ad·min·is·tra·tor
http://www.polishinginc.com/
Old Oct 25, 2004 | 01:04 PM
MrGone's Avatar
because Nissan likes 2-4-6 more than 1-3-5.
Old Oct 25, 2004 | 06:19 PM
Cliff Clavin's Avatar
Way out West
Originally Posted by DanNY
hmm, maybe I could get some stuff polished just for fun.
Have you used this guy before, Dan?
Old Nov 7, 2004 | 06:38 PM
VQuick's Avatar
Chassis Freak
Hmm, anyone have any other online recommendations for polishers? Where would I look for them in the phone book? Local would certainly beat shipping, but I want the best job possible for the money.
I want my intake manifold sanded smooth and then polished, and also my valve cover.
TKHanson
Nov 24, 2018 01:39 AM
jonreidhead
Jan 6, 2016 09:38 AM
tseng1023
Oct 15, 2015 08:30 AM
JonBlz
Oct 5, 2015 06:02 PM
hayne
Oct 5, 2015 11:53 AM
