02-03 maxima with zex?
Old Nov 1, 2004 | 07:43 PM
02altima's Avatar
i ned some pics for refrences for my installl so if any of you have the zex system. can you please post pictures of your under the hood set up of the zex system...the ''show me your nitrous set''thread didint have any 02-03 maxima set up..your help will be appreciated..thanks again
Old Nov 1, 2004 | 07:54 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I don't have NOS but here it might help:
http://forums.maxima.org/showthread....hlight=nitrous
Old Nov 3, 2004 | 06:23 AM
ddpack's Avatar
Don't have any pictures but installation was like this:
1) Nitrous bottle in passenger side of trunk, ran line under drivers side door sills
2) Nitrous management unit on firewall slightly towards driver and down as low as possible
3) Nitrous switch in center console in one of the blanks not used with my SE
4) Wet nozzle under rubber connector between MAF sensor and throttle body
I'm only usin a 55 shot but it makes alot of difference, especially at sea level. Hope this helps, if you really need pictures, post again and I''ll get some
Old Nov 3, 2004 | 05:54 PM
02altima's Avatar
what type of fuel line connectors did you use??i did everything alread except connecting it to the fuel line??will the one that was given be acceptable to use?thanks again for your help
Old Nov 3, 2004 | 05:56 PM
02altima's Avatar
and yea i forgot if you can get pics it would help alot thanks again
Old Nov 4, 2004 | 04:58 PM
nismo_star's Avatar
I'm using a ZEX setup, bottle in trunk on pass side, optima yellow drivers side, line runs down center hump of vehicle under carpet to zex control unit behind dash
ran line through firewall since i had to replace my heater core anyway purge solenoid mounted on rubber bushing on firewall inside, line runs in front of wiper cowl out in a V pattern 75shot tuned. Used CONSULT to retard timing 2 degrees with 1step cold copper NGKs.
halfpol
Oct 17, 2022 12:16 PM
Goffery2uned
Aug 21, 2015 09:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
