MEVI burnout
MEVI burnout
I recently installed cattman headers, warpspeed MS cat, and Greddy SP2. Now, at WOT in first gear when MEVI kicks in at 5250 my tires cut loose all the way to redline. Does any one else with similar mods expierence this traction problem?
Your tires must be horrible. And this seems like BS because at MEVI switchover, there is no power added, it just keeps building and holds, but there are no power spikes to cause tires to break loose.
Originally Posted by CystumMax
Wow that's some helpful information you just gave.
I know,I know i was kidding around but the truth is most maxima's can do this. Especially in first gear, Short gearing and decent torque are all that is needed. My MAX can do it. Now if he said his car was doing this in second gear that would be super cool but he has a pretty nice setup none the less.
Well, from what I understood from his post, he's at WOT, then suddenly, at MEVI switchover, it breaks loose.
I believe what Jeff said, because my cars do it if cruising ---> then floored, yes, possible, but not due to MEVI switchover alone as what seemed he meant by his post.
Just have your MEVI inspected every 30k miles. I hear that some of them fail, and the screws loosen up from the butterfly, and the actual butter fly falls into the engine.
-matt
Originally Posted by NmexMAX
The small screws that attatch the butterfly to the actuator get loose and may fall in, but I've never heard of the actual butterfly getting sucked up.
I know it is not the variable intake engaging that causes the tires to slip. Peak power is at higher rpm's which is amplified by the intake, possibly causing it to push the tires over the edge. Compared to a stock setup where the power curve falls off past 5k.
I used lock-tight on the butterfly screws, this worked very well, I just checked them after about 7k miles and they were all still tight.
man...I have every NA mod known to man except headers, flywheel and cams and ever since I went from the USIM to MEVI, I can't break loose my tires from a roll in first no matter what I do...(I have goodyear GS-D3 235/45/17...brand new...and eibach springs, kyb gr2's)...with the USIM, with it's extra midrange....I was able to break it loose, but only with my old, crapped out 235/45 kumho's...wish my ride had that ability back...that was cool!!! bad for the tranny, but cool!!!
Damn i can spin at any rpm in first but then I have the torquey mod a VQ35 bottomend just punch the gas and instant redline at any rpm in first. I can even get chirps out of 2nd just flooring it sometimes
http://www.nismoparts.com/catalog/?section=577
Courtesy stopped selling it.
Originally Posted by Sizzam
where can i get a MEVI for my 1996 max. i have been looking everywhere and i cant seem to find someone that sells it.
litch
123
Jan 4, 2024 07:01 PM
