Does a faulty IACV cause my Max to die when...
Does a faulty IACV cause my Max to die when it reaches about 4k - 4.5k rpm's ?
I've had the check engine light giving me this code for the IACV for almost about a year and the only problem I've had is low rpm's at idle. But since last week my car just wants to shut off when it reaches those rpm's. The only codes that my check engine has given me are the IACV and the rear O2 sensor which I've had since a loooong time ago.
Should the problem be fixed by replacing the IACV? Or does this not have anything to do with the rpms dying at 4k rpms ?
Thanks in advance to anyone who helps.
Originally Posted by s0ber
Sounds like a bad MAF.. hmm
Yeah That's what I thought. But the Check Engine is not giving me the code for the MAF. And I don't want to spend money on a MAF if I'm not sure that's the problem.
I would tell another Maxima owner to let me try my car out with their MAF just for testing but here in Puerto Rico there aren't much 4th gen Maximas.
Is it possible that the Check Engine won't recognize a faulty MAF?
I believe a faulty MAF wont trigger a CEL unless its totally blown... Not sure though.
http://forums.maxima.org/showthread.php?t=357680
The "stage 1" of bad MAF symptoms is EXACTLY what's happening in my case. I guess that must be it then, but I'll still try to test another MAF on my car before buying one.
Thanks to all who replied, you've been of great help
Originally Posted by StAtiXz6
Ramz i told u already......Maf symtom's that happen to me ill classify them in Stages.
Stage 1: Maf slightly damaged *rev till 4100 rpm and car would lose ALL torque and power and just bog out.*
Stage 2: Maf damaged more *rev till 3000 rpm car would bog out and go timing retarded till redline*
Stage 3: This time i heard the maf pop *rev till 2200 and car wouldnt pass that as if some one ripped my car a new ******* and it couldnt move no more........poor car..
LISTEN TO UR ELDERS RAMZ lol XD ^_^
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
jds22
Sep 29, 2015 02:03 PM
