what is a trans range sensor circuit????
Can anyone please help me understand the code i got from my car due to the check engine light being on? The code im getting is P0705 which autozone told me its the Trans Range Sensor Circuit Malfunction then after that it said PRNDL input "whatever that means" can someone who has experienced this code please PM me or post on the subject
I'm looking at the FSM now and it says P0705 ( MIL 1101) deals with Inhibitor swich (in english - this is your Park-Neutral switch )
The malfunction is detected when- TCM does not receive the correct voltage signal from the swich based on the gear position.
Check for harnes and connectors ( the circuit could be short or open)
Is your car driveable now ? does it start ?
Thats all the help i can provide now - get the FSM - it has lots of priceless info.
Nick.
Nick.
Plus i have the chilton manual and it does say that this code has something to do with the sensor as explained above, but reading through the stickies it defines this code as a probem with the Evaprotive emission control system can anyone else that's had this problem tell me what they did to fix?????????holla
this is my problem, now even tho this is old, i would like to bring it back up in hopes of somebody knowing a answer to this problem? how can i fix my issue... i believe this is what is keeping me from driving my car normally with my lights on. with my lights on my car will not shift past 3rd gear. but with it off it works absolutely fine.
holy batman this 5 years ago.....i got the same code and i have no issues with it i can pull through all 3 gears on L then 4th on 2 and all of them on D. lift the car up check the Inhibitor switch on your tranny go to pmohr for the fsm and search for solutions.
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
