problems with new tires..air leaking?
Old Dec 19, 2004 | 10:07 AM
OpTi's Avatar
I just got 4 new goodyear tires at pep boys. Every 2 weeks, it loses about 5 psi. I bought it back to pep boys and they say that everything seems fine. Does anyone know what could be wrong?
Old Dec 19, 2004 | 10:10 AM
njmaxseltd's Avatar
Two things to check.
1) Did you get new valve stems with the tires?
2) Have them unmount the tire(s) clean the bead area on the rim & tire(s) and remount them.
Old Dec 19, 2004 | 10:34 AM
Vyrus's Avatar
They shouldn't be leaking that much, something is wrong.
-Cyrus
Old Dec 19, 2004 | 10:51 AM
Conrad283's Avatar
I need a truck
When that happened to me it was the valve stems.
Old Dec 19, 2004 | 12:37 PM
OpTi's Avatar
how do i check/fix the valve stem?
Old Dec 19, 2004 | 12:51 PM
R.I.P. Grandma's Avatar
I actually have the same situation with my falkens
Old Dec 19, 2004 | 01:21 PM
wolfpack_5150's Avatar
Apple Pie Monster
Spray soapy water around the valve stem, sides and top...Make sure u remove the cap. Then move the stem all around and look for bubbles. If u see bubbles take it back and have the stems replaced..Also you may wanna do the same around the wheel weights, unless they used sticky weights there is a possibility that air is leaking around them and the tire...It happens.
Old Dec 19, 2004 | 02:16 PM
NYC TAR's Avatar
^^^ also, you need to put alot of air in to make this work. like 38- 40 lb of air.
Old Dec 19, 2004 | 08:34 PM
Apple Pie Monster
You are correct, sorry I work 3rd shift and was half asleep already...yeah when I did tires we would put like 50psi in the tires and it would work..
Good lookin out NYC TAR
Mar 12, 2020 12:06 AM
knight_yyz
Oct 24, 2015 08:05 AM
dcam0326
Sep 18, 2015 04:52 PM
