Cant remove gauges
Old Dec 20, 2004 | 03:11 PM
rsly33's Avatar
Cant remove gauges
I wanted to put in some gauge rings and I have everything out but, I cant pull out the dash. Ive snapped out the majority of the clips I think because it moves alot, but it still wont budge. Can anyone help me out or tell me where the clips are.
Old Dec 20, 2004 | 03:34 PM
MAXRB8's Avatar
Have you removed the 3 phillips screws supporting the gauge cluster? One on top two below
Old Dec 20, 2004 | 04:24 PM
pavelsmax's Avatar
what exactly do you have out
need to remove lower plastic piece by your knees
then metal brace
then 4 screws removing top steering wheel column trim
then take out the dimmer security switches
make sure wheel is tilted all the way down too
then 2 screws around top trim
that has clips along the bottom just put your fingers in the holes for the dimmer switches
pop it out then 3 screws for gauges
Old Dec 20, 2004 | 04:30 PM
jackiss2888's Avatar
defintely make sure the three screws (one top, two lower) are out, then it will almost fall out on its own. Then disconnect the three wire harnesses on the back of the cluster.
Old Dec 20, 2004 | 06:12 PM
KsuMax's Avatar
Cheesing away...
after you have them all out, make sure you don't break/crack the clear plastic cover that protects the guages, like I did
Old Dec 20, 2004 | 07:21 PM
holy poop, me too! did you get a replacment? how much and where?
Old Dec 20, 2004 | 10:32 PM
KsuMax's Avatar
Cheesing away...
Right now, I'm just living with it. You can get a replacement at the dealership for like $15
Old Dec 21, 2004 | 04:32 AM
only 15? nice, a friend of mine went and found out for me and he said they said like 35. if need be and that is the case, can i send you the money and you get it from ur dealer then send it to me?
Old Dec 21, 2004 | 09:40 AM
KsuMax's Avatar
Cheesing away...
I'll let you know how much I get mine for whenever I decide to order one. It could be $30, I can't remember
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
