remove thermostat when flush coolant?
Old Jan 1, 2005 | 05:42 PM
tian's Avatar
is it necessary to remove thermostat to thoroughly flush the cooling system?
is it easy to remove the thermostat? do you have to remove the drive belts and idler pulley bracket first?
do you (how often) replace thermostat? is there a usual life span for it?
Old Jan 1, 2005 | 06:17 PM
chuckie311's Avatar
read the Stickies its in there
http://www.motorvate.ca/mvp.php/502
Old Jan 1, 2005 | 07:11 PM
tian's Avatar
i did read it. that's basically FSM procedure. problem is, i think this procedure doesn't really flush the whole system if you don't remove thermostat.
and i still don't know if/when thermostat breakdown/replacement will be a problem.
Old Jan 1, 2005 | 08:11 PM
Igobuk's Avatar
If you want to do a proper coolant flush, you have to remove the thermostat.
The only other option is to heat up the engine so the thermostat opens up but then you'd be doing a flush with scalding hot coolant.
Just remove the thermostat, it's not that hard at all. The Haynes manual has a great how-to. And you won't burn your hands.
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
