Fuel return line???
Thanks, I wanted to run a 35 shot (or so) with this system, but it says no fuel return line.
http://www.venom-performance.com/nf/...tech.htm#tech2
It can only be a returnless system if the fuel regulator is in the fuel tank. I have never seen any flavor of DE-K on my lift at the shop that didnt have the fuel return line. Sloppymax has a '01 AE which is a 4 O2 sensor Cali spec car. I changed his fuel filter which is in the fuel tank and it did have the return line and line fitting on the top of the cartridge. His regulator is exactly where it says it is in the ESM and not in the fuel tank like my 2k2. If you have something different then I certainly want to see it for future reference.
Originally Posted by Haterz
what about the fed specs, are they different???
Us 5th gen don't run dry shot of nitrous because there is no fuel return line. That's the reason we only run wet shot.
That is what I've always read in the nitrous system. I"m not talking from first had experience so hopefully BlackBIRDVQ and SR20DEN can clear this up for you.
Thanks for the help SR20DEN. Are you familiar with the zex "dry" kits. I just want a sneaky small shot 35-55 max. I'm not sure about the vacuum ported fuel pressure regulator and throttle position sensor voltage part though.
# ZEX™ Nitrous Compatibility Checklist
* Engine must have a vacuum ported fuel pressure regulator
* Throttle position sensor voltage must pass the following test:
o Locate the T.P.S. (usually directly across from throttle linkage)
o Turn ignition to on position (do not start engine)
o Using a digital voltmeter, check each wire for a low voltage reading of approximately 1 volt.
o Only one wire should have this low voltage with the throttle closed
o While on that same wire, open the throttle completely and check the voltage reading
o If your voltage reads 4.2 volts or higher, you are ready to install your ZEX nitrous kit
ok, let ME set this straight!! not only do i have an 2k1 cali spec max but i'm a tech for a nissan dealer and have been for over 6 yrs, and i have worked on atleast 5,000 2k and 2k1 maxima's and of all 5k not one of them had only i fuel line. THEY ALL HAVE A FUEL RETURN LINE. PERIOD........................................ if you want more proof,
what is the main reason stillen has left out all you 2k2 and up guys on the supercharger?
ANSWER: they 2k2 and NEWER have NO return line, which untill recently was the main reason stillen did not include all vq3.5 motors......
ALL vq30 motors in maxima's have fuel systems with a fuel return line, 2k and 2k1 do NOT have a servicable fuel filter but it does not mean there are not 2 lines, because there are and a gaurantee that they all do
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
