Adjustable valves ??
My valves at idle completely warm have a pretty good noice coming from them...i have 87,000 on it and i dont know if the guy before me has ever done it...are they adjustable and is it a normal thing to do to a car ?? thanks
:radbounce
:radbounce
4Gen valve adjustment procedure
Originally posted by matty
My valves at idle completely warm have a pretty good noice coming from them...i have 87,000 on it and i dont know if the guy before me has ever done it...are they adjustable and is it a normal thing to do to a car ?? ...
Adjusting valve clearance not as simple as turning an adjustment screw. Each cam lobe bears directly against a disk-shaped steel shim of precisely machined dimensions. Changing valve clearance is done by removing the shim and substituting another with a different thickness. This service procedure requires special tools. The shims are made in thicknesses ranging from 2.32mm to 2.95mm. They can be purchased from the dealer. I'm not aware of any other source for these shims.
See Chilton (page 1-30) or Haynes (page 2B-5).
:radbounce
:radbounce
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
