Current Nitrous users/experts
Old Feb 7, 2005 | 06:33 PM
GusMaxGLE
I am looking at purchasing an NX Nitrous Express MainLine kit for $379 shipped. What is the diference btween a "dry" system and a "wet" system? Is there any other mods I need to run nitrous, like injectors, plugs, or do I need an ECU upgrade?
Looking for reliable HP upgrade that won't damage my Max!
Also, is the nitrous kit easy to install?
Old Feb 7, 2005 | 07:17 PM
MaximaPolak's Avatar
go to the nitrous threads and post there...should be some people who can help you.
http://forums.maxima.org/forumdisplay.php?f=55
Old Feb 7, 2005 | 09:35 PM
DonGfun's Avatar
VW = 30 MPG
This is the kit I got
Wet is safer then dry.
http://forums.maxima.org/showthread.php?t=368479
Old Feb 9, 2005 | 08:45 PM
TAPOUT's Avatar
You will lose
On a 2K3 wet is the only way you should go because there is no fuel return line.
Old Feb 9, 2005 | 08:57 PM
SonicDust187's Avatar
I would not get he main line kit because it comes with a 9 foot hose and you need one more of about 13-14' hose. Get the normal NX kit from Nopi, its $440.
Old Feb 9, 2005 | 11:23 PM
frankd121's Avatar
Go with a wet kit... you won't need to upgrade your injectors since the nitrous/fuel is mixed and sprayed into the intake (midpipe, after MAF). If you have the money, go with the ZEX kit or try to find one used...mine's coming in soon...
Old Feb 10, 2005 | 06:19 AM
TAPOUT's Avatar
You will lose
You can also just put a kit together, if you can but a bottle and two solenoids, a nozzle, and have some lines made. I had almost all of the lines for my system custom cut, and it is not that expensive. You also need a couple of switches, and relays. When you buy a kit, all it is is a bunch of these same parts in one box. The bottle is the most expensive part of the whole thing. It is real nice to have more than one bottle, so you can have back up when the first one runs out. Also nice to get your son to watch over it while you are racing...
Old Feb 16, 2005 | 11:44 AM
TJ_Max's Avatar
Paradox Systems Vendor
i have the mainline kit, and i vouch for this....i had to buy a new freakin line and the lines going from my solenoids to my nozzle are so short, i had to mount the solenoids very close to the nozzle in the intake (it sucks), gotta order new lines for those...
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
soybeanz
Sep 25, 2015 10:46 AM
