Radiator covered under warrenty?
Hey guys,
I need some info.. Okay so my radiator is cracked and leaking at the top, but not leaking on the bottom?? yeah i dont know.. So i was wondering if it would be covered under the warrenty considering its not a wear and tear item.. Or is it?
thanks
thanks
Originally Posted by nyautostyle
Hey guys,
thanks
thanks
thanks soonerfan, any place in particular? I got a quote from radiators.com for $229 and a year warrenty, or $249 for two-year warrenty.
Also is the installion complicated?
install is pretty easy
drain coolant
disconnect upper and lower hoses
if you are an auto - disconnect tranny fluid lines from bottom of radiator (pink the ends off somehow so all the fluid doesnt run out
disconnect fan wire harness
remove two nuts and bracket from top of radiator
pull radiator out
remove fans from radiator
install in reverse order
im pretty sure thats it..if i forgot a step you should be able to figure it out
Unclejunebug
Apr 2, 2016 05:42 AM
