idle RPm adjustment
Old Mar 1, 2005 | 08:39 AM
ziya20's Avatar
idle RPm adjustment
Hello all,
I need to adjust idle rpm because I have replaced and adjusted TPS.
Could anybody help me with this how to.
I have already tried the method from Hynes manual when you put ecu in selfdiag mode and then turn the idle screw on IACV but thgis did not change the idle rpm. So I am guessing that there should be another way to do this.
I will appreciate your help.
Old Mar 1, 2005 | 08:54 AM
2 Da Max's Avatar
well the screw is the only way, unless the computer wants it to be at that, whats the rpm at idle?
Old Mar 1, 2005 | 09:01 AM
ziya20's Avatar
Idle with trans in D is 600.
Should I remove TPS cable when adjusting RPM?
maxjetblack's Avatar
where is that plastic screw anyway?
Old Mar 1, 2005 | 11:05 AM
ziya20's Avatar
Hey guys I need your insight please. any answer?
( by the way the screw is on top of IACV)
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
