100 LEDs received, have ? about Wiring it to Sources
yeh, got my 50 5mm blue leds and 50 3mm w/ free resistors for like $17.
i remember tryin to wire up an led to the keyring light and it blew. is it b/c of the diff wattage or something? i also thought about making 3 rows of LED for the glove box since i have so many connected to the 194 bulb. Will this be able to handle it or blow out?
i have many other unique ideas and will have pics very soon.
will start later today.
That's awesome. Where are the write-ups for what LEDs/Resistors to use? I wouldn't mind making my interior like that, but maybe a dark green to match the paint. As for the tails, they're called GenII Altezzas. Installed them myself last night, the Gunmetal version looks amazing on my car - and at night = !!!! BEAUTIFUL! First night out and got some necks breakin'.
tezza's+no performance mods+lots of pretty leds=
LED's draw very little power - they will burn out easily if you connect it straight to a 12V source like the 194 bulb socket. If you use the resistors correctly you shouldn't have a problem. I would reccomend running a seperate wire from another 12V source (fusebox is usually the best bet) if you want to run a lot of LED's in a row.
alright i actually ended up doin 5 LEDs wires up to the 194 bulb socket wires.
worked fine and looks beautiful. i have a bunch of other led mods, the 9 led dome ligh that is also connected to my 3 row led door lights and also some others.
car won't start up now. it trys to start but fails. i'm spazzin out and my parents don't know about it yet. i need help...
well the glove box bulb is a 194 so u don't recommend me doin this?
wiring diagram:
done in 2 mins with ms paint so, yes, it ain't pretty. you get the basic idea tho
Originally Posted by Cant_Get_Ryte
so the resistor is on ground? or am i misreading? i was looking into doing this but thought the resistor was on the positive side, does that change with multiple leds?
well i put them for pos. i did the glovebox LEDs. 5 rows of LEDs wired parrallel i believe, its been a long time since i took physics. anyways, they work great and will have pics of everything later.
also my driver side window switch LEDs wont work now by its still functional. i kinda pulled up on the green stuff attached to the board but do u think that might of affected it?
Your making me want to put LEDs throughout my whole car. I'm wondering if I could complete such a big task.
What size and mcd rating LEDs did you guys use for your interior pieces such as the air vents, door handles, etc.?
Yes, I did the same thing. I bought a new LED board and soldered the LEDs over again.
plus you u need to have a bunch of LEDs and resistors cause i blew out a bunch.
5mm are 5000k i think and the 3mm are 7000k. there perfect for me. you have to have patients and a lot of time and knowledge of LEDs. hey where did u get ur board, and how much?
well i can tell u this now, it is gonna take you a long time if u wanna go all out like me.
Hdnseek
Sep 9, 2015 05:55 AM
