Vacuum Line Dilemma
Vacuum Line Dilemma
I changed out my fuel injectors on a 94 Max SOHC, labeled just about all of the hoses and wires, except one!! A small vacuum line connected to a plastic male on the left rear of the plenum leads to nowhere obvious. Can anyone help.
for others view pics at
http://www.cardomain.com/memberpage/748507/1
No, never found it by the manifold. #15 on the picture is the line I'm referring to but it is not long enough to reach the heater valve attached to the firewall. So, it doesn't seem to go there.
Befuddling!!!
Befuddling!!!
Befuddling!!!
Befuddling!!!
As far as I know, VG30E intake has one port at LH, one port at RH.
LH is small, goes to heater valve at firewall.
RH is thicker, goes to gas pressure valve at right.
Anyways, manifold vacuum ports have to be closed, otherwise idle is not good.
Ok, I'll try to work it over there again. Seems right though, because the valve does have what appears to be 2 vacuum connections, so somehow it has to reach!
15. ...........Vacuum line from intake; hose contains small oneway valve.
14. ............Magnetic valve for vacuum control.
14b. ..........Vacuum line link from magnetic valve to vacuum actuator.
14c. ...........Vacuum actuator arm moves the actual water hose (7.) valve.
14d. ...........Inset: (Mechanical) Water Valve is 'hidden' under the assembly.
16. ...........Electronic control wiring from cabin. Note the diode -mark on the connector.
Checkout http://www.cardomain.com/memberpage/748507/8
#15 is a very thin hose, it goes almost all the way towards the passenger side of the intake manifiold, where it comes into a small plastic step-up adapter. The other side of the adapter is attached to about 2" long 4mm ID hose, that goes into the pipe on the manifold. I just replaced mine last week so I remember this one. Hope that helps.
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
