What Spark Plugs are the best for the Maxima???
I'm getting crappy gas mileage and need to change out my Spark plugs. I have a 98 Miaxima with 120k miles. I heard the NGK plAtinums are the best for the Maxima. Any other opinions or experience would be appreciated, Thanks in advance.
Greg
Greg
ok bro...check it....this is very important to know...IMPLANT it in your head.....and theres no other alternative.....you must use NGK plugs for your max.....ive heard many-a-stories from people who put in bosch plugs and screw up the way there engine runs and performs....its very important that you use NGK plugs....next..PLATINUM is oem and the car will run the best with these plugs...you can use copper NGKS as well....both are fine....platinums will get you 60K and copper will last 30K......just go to the dealer and ask for plugs-they are pre-gapped...no worries..I use platinum and I have peace of mind....you can use copper as well-its also a lot cheaper....but I like platinum
Originally Posted by 97PKIMVQ
I agree I had myh plugs changed two days ago. And they reccomended me only NGK's. So I got factory plugs and got them in. The guy I bought my car from never changed them so when the plugs came out... they were all rusted. NGK's will run you 60k. USE NGK.
Thanks for your help guys. That was my first choice, but I just needed some input to make sure is was the right choice. Thanks again.
I dont stick my **** in anything without a condom....I wouldnt put plugs in my max unless they were NGK PLATINUMS.... PERIOD....no bosch, no nothing....anything else in time will damage your engine internals....questwest your crazy for running bosch man-I cant believe you dont have any probs...call the dealer and tell them what your using, see what they say
http://maxmods.dyndns.org/index.php?MaximaSparkPlugs
Go with NGK coppers. BKR5E-11 if stock or bolts ons. Make sure they are gapped to .0433in or 1.1mm because sometimes they can be gapped wrong out of the box.
Iridiums are the best performance, then Coppers, and then platinums. Platinums last longer but are much more expensive than coppers. Iridiums are mainly for boosted or nitrous people. They are the only people that would notice anything really different performance wise over coppers.
Once again NGK ONLY!!!!
Originally Posted by questwest
I have had Bosch Platinum 4+ in for more than 10k now and it runs perfect. Very good mpg and performance wise no problems at all. bought it online for 28 bucks.
Ive heard horror stories from several mechanics saying bosch +4 causes the oem coilpack to spike and fail prematurely. ...no worth it for me
Originally Posted by maximazation
im running ngk iridiums, working perfectly for me
speaking of cleaning air filters, i have an air filter that i baught my car with, and it has the rubber around it colored orange and has a metal grill on the filter itself, is this is a fram? and is it reuasble, as in washable or reoilable?
Okay... I have to ask....
What the heck is the big deal with never using anything but NGK plugs? What makes them so special?
There are laws about merchantability that state that you can't sell something if it causes unreasonable harm... I could see how Bosch and Denso plugs might theoretically not work as well, but how the heck could they cause damage to your engine?
Originally Posted by rmurdoch
Why don't you put them in and find out? If a friend told you not to jump off a cliff because you might kill yourself, would you do it just to find out, lol?
But.... there has to be a reason why everyone kicks and screams about NGK plugs. If there isn't, I'd love to expose the false rumor....
doodfood...the reason why you have to use NGK...bosch and all the other plugs are bad for your coil packs....the other brands create the wrong kind of spark needed for your nissan maxima...your coil packs will fail faster with the use of bosch and etc...do you know how much coil packs cost??.....use NGK plat or copper....how can you debate the FACTORY OEM NISSAN PLUGS!!!!!!!!!!!!!!!!!!!!!!!!
Then you might as well run 87 octane and the crappiest oil you can find because after 6,500 miles you might not notice any problems
either!
either!
Good point. But the thing is, I can tell you exactly why those things are bad:
87 octane fuel:
- Increases the chance of knocking because it's easier to ignite
- May lower fuel economy because you get less energy from burning it
Crappy oil:
- Doesn't lubricate as well in general, causing more wear
- Doesn't maintain its characteristics well over a range of operating conditions
These things are common knowledge. On the topic of spark plugs, though, I just haven't heard actual explanations of exactly what it is about Denso and Bosch plugs that makes them unsuitable.... just a bunch of claims that it will bust your engine.
Same reason people debate the factory intake, flywheel, exhaust, clutch, etc.... because if I can, I want to make it better.
HA! Tough question, eh? Seems there might be a misconception here... Maybe it's time to start a thread and see what people say...
EDIT: referring to my spark plug question, not the part # questions.
i had this car for 2 years now and i drive it every day like i stole it, unless it snows like crazy then i'll drive my ML. i went thru 2 sets of tires already on my third now. as far as the mods go i have very little done: ACT stage 1, brembo rotors cross drilled, ss lines for brakes and clutch are coming, stillen sts, exhaust tech muffler, K&N air filter, 17" OZ superleggera w Kumho Exsta 712.
in 96 i bought brand new Infiniti I30t and used bocsh plugs as well that car had 50k in 99 when i traded it in. it was pearl white with biege interior, 17" racing seneka wheels pirelli supersport 7000 and remus muffler. and i also use bocsh oil filters.
NGK makes some very good plugs like Iridium IX, but i like the idea of having 4 contacts instead of one.
Custom Maxima/enterprises sells a lot of things that are
. They never cease to amaze me.
Questwest, I don't mean to insult but we don't need your life story. Having four contact points is a gimmick.
The NGK part numbers for stock heat range is
copper: BKR5E-11
Iridium: BKR5EIX-11
platinum: PFR5G-11
I am not sure about the Nissan part numbers if that is what you are talking about but any nissan dealer should be able to tell you
Nissan claims you are supposed to use NGK. It might be a gimmick that they came up with to get more money to NGK but then again I would rather just spend a few more cents to put a little trust into nissan.
. They never cease to amaze me.Questwest, I don't mean to insult but we don't need your life story. Having four contact points is a gimmick.
copper: BKR5E-11
Iridium: BKR5EIX-11
platinum: PFR5G-11
Originally Posted by maxmods.dyndns.org
Only run NGK spark plugs in the Nissan engine. This point cannot be stressed enough. The engine and ignition system was designed with the internal resistance and exact parameters of NGK spark plugs in mind. Maybe some people have had some success stories running other brands, but others have lost 15hp, have lost gas mileage, have hesitation problems, or had to replace their whole engine, just by running non-NGK plugs. Don't say we didn't warn you ahead of time.
Fair point. Honestly, for anyone who isn't as much of a skeptic about "what they say you should do" as I am, there's little reason to take a chance.
On the flipside, I just can't imagine that anyone would put out a spark plug that they would damage an engine. I can see how a Bosch 4-tip platinum plug would have quality issues because it's so cheap, but Denso (and NGK for that matter) is much better quality.
I repeat.... what exactly is so special about NGK?? Does Nissan have a reason for insisting on them, or is it just marketing hype?
The OEM Nissan part number for copper BKR5E-11 is 22401 - 50Y05.
Here is a 3 page thread about this same subject. I hope that starts to help clear things up. I don't have any substantial evidence such as a Nissan document stating why NGK Platinums are to be used only (since they don't even like us to use copper), but from every post I have seen on the org there are some horror stories that were solved by switching back to NGK.
http://forums.maxima.org/showthread.php?t=344876
Alright, checked that other thread... After sorting through the flame war, here are the only facts I've seen that actually had real evidence, science, or professional opinion backing them up:
1. Copper plugs generate a slightly hotter spark than platinum for a given voltage (copper has a higher electrical conductivity).
2. Copper plugs wear out faster than platinum plugs, and their performance deteriorates with age while platinum plugs do not (copper is softer and has a lower melting point than platinum).
3. From a link in the forum:
This may explain some of the Bosch power loss/engine damage stories. Also...
The specified gap for the Denso Iridiums is the same as for the NGK Platinums; therefore, the Densos require less voltage.
This leads to a neat explanation:
1. Copper and iridium plugs make a better spark with less strain on the ignition system. This is why some people swear by them.
2. Copper plugs wear out fairly quickly, and as they wear out, performance is degraded and there is a greater chance of misfire or other problems. Maybe some people didn't catch this happening, and blew something up. This may explain the horror stories.
3. Bosch 4-tip plugs are really cheap, which probably means that they have loose quality control. You can't gap them to make up for it, and they may create gas flow problems in our ignition chambers. Some of these plugs will be good and others will be bad.
Conclusion: The STEALERSHIP lives up to its name, NGKs are just really high quality plugs and nothing more, Denso and NGK iridium plugs are great, NGK copper plugs are great but be careful with them, and don't use no-name brand plugs.
Now, someone argue with me. Let's rock.
Originally Posted by http://www.spark-plugs.co.uk/pages/technical/spark_plugs_faq.htm
Q9. Do my multi ground electrode plug outperform single ground plugs?
A9. In most cases, no. The additional electrodes disturb the flow of gases around the spark plug tip and if anything performance is reduced. In addition, for high performance applications the additional metal within the combustion chamber will retain more heat and may be more prone to detonation/pre ignition.
The nature of Iridium spark plugs means that they are able to utilise a larger gap setting while actually requiring less voltage and straining the ignition system less.
