How to get rid of Odor smell in car
Well How to? what to use... I have clean the interior, detail the car and nothing... what the heck is wrong.....I hardly use the car....
I work in a restaurant, the smell comes home with me and into my seats. Its nasty.
I just febreze all the cloth seating surfaces, carpets, and headliner. That seems to do the trick. I keep the carpets washed pretty well. I give a can of auto fabric cleaner and a scrub brush to one of my kitchen slaves and have them scrub and rinse the mats in the big wash sinks we have.
Works like a charm and I don't get my hands dirty. lol
CM
Works like a charm and I don't get my hands dirty. lolCM
run the heater for a while, and then run the ac for a while, then turn off the ac and let the blower motor just blow on high.. let it do that for a while.. hopefully any mildew would dry up in ur ac system
CM
i have had good luck with the febreze stuff as well, i got a rental while the max needed paint work and it smelled like a-hole, the febreze took care of it...
Lontar, Febreeze all the carpeted surfaces (headliner especially)
then,run some lysol thru the A/c intake then put the system on recirc for a few min. If it still wont go away, PM me and I will see what I can help you do next time im up in orlando.
Originally Posted by Lontar1
it is like humidity.. and I hate it.......
Two things will work perfectly for you....
One: Get some Wurth A/C & heating system cleaner. Works REALLY well at getting rid of that EXACT odor. Follow the link below...
http://www.autogeek.net/wuachesytr.html
Also, go to Target and get some Febreze Auto. I use it every time I clean my car and it really smells like that "new car" smell.
Originally Posted by d50ross
Acutally what I do is buy a box of Bounce Dryer sheets and put one under each seat every week when I finish washing it. It keeps the car smelling fresh.
Christina
CM
Originally Posted by PrinzII
I also recommend Wurth's odor eliminator. I have that and it leaves a very nice odor.
Dont know of any local places in your area (or mine for that matter). I had to order it online, but you can go to wurth's website and they will put you in contact with your local rep that will sell to you. I contacted my local rep AFTER I paid 20 dollars a can and I could have gotten it for 15 bucks each when I bought three! Ill be doing that next time.
oh and .... www.wurthusa.com
You know what, I did the lysol method and that worked out pretty well. Can only costed me $3.50 too. Started off by spraying every vent in side my car, let it sit for about 5 mins. Then threw the AC on full while the car was running and started spraying it into the AC intake vent. Did that for a good 5 mins then let the ac run on its own for awhile. Finished it off by spraying some Meguiars Carpet cleaner solution down the intake vent to give the car a nice smell. Lysol smelled great too, but I like this stuff more.
No more meldew smell from the lower vents.
Even if you use spray you might want to clean your fan. I cleaned mine and it was filthy. Even if you have microfilters you need to remove the fan usually found under the passenger side dash. Take out the screws and then take some rubbing alcohol or bleach mixed with water and start scrapping it off. You will definately notice the difference when you turn on your air condition, heater, and or fan.
they do it when you get the in-cabin microfilter changed (at least at my dealer)
You still should check on it and make sure. The stuff probably won't kill you but you could get ill. And if you have small children it should be top priority.
No need, if you properly maintain your system. I swap the filter and clean the fans (plus run ozium thru) every 15k.
Condensation always form on the fan, it's circular with straight blades and there are over twenty of them. Not even the best microfilter is going to stop bacteria or whatever the black stuff is from forming on them. The only thing that can possibly be sprayed on them to kill the blackness would be bleach.
I had that in the A/C and tried to trouble shoot it for awhile untill my GF sprayed her perfume in the vents one day. I would go with a neutralizer or possibly a scent you dont mind. It has worked for me, there is just no smell now.
