engine feels like its about to die (just used 87 octane)
I am confused about this issue i got in my car tonight. I was driving slowly when all of a sudden my car started to shake, like it had a flat tire. I noticed when i came to a stop that the car kept shaking, so that quickly ruled out a flat. If i put the car into neutral, the car stopped shaking but I could hear that the engine was struggling. I just put 87 octane gas in my car the other day b/c the gas prices just went up.
I'm convinced that its a fuel injection issue or I BADLY need a tuneup. I put a fuel enhancer into my gas tank to hopefully clean it a bit overnight. Has anyone else ever noticed this on their maxima? If you did... what was the solution???
thanks in adv.
thanks in adv.
your car struggling is probably the knocking and pinging of the engine due to predetonation. dont use 87, use whatever your premium is. in california, its 91, and elsewhere in other states its like 92 or 93. hope this helps.
Your problem is probably much deeper than that, like you said a fuel injection problem, or whatever. It might even be your coil packs going bad. Wait and see if your CEL comes on, and what year Maxima do you have?
its a 95 maxima. I use to use 89 or 90 before I put it in the 87 (so it wasnt that big of a jump). Should I even try to drive it to the gas station? I dont think i can even go over 10 mph and Im afraid im gona do engine damage if i drive it like this anywhere. I just left it near a parking lot where it started dying.
Turbo mate - all Maxima's require at a minimum 91 octane gas. Otherwise, you're going to damage your engine. It's not designed to use such low quality octane and as a result the engine ECU and components have to struggle to make it work ~ increasing the wear and tear on your engine.
Suck it up dude. Own a Max - you gotta put the 91 in. No exceptions. Otherwise you'll eventually kill the engine.
Try not to use 87 , at the worst use 89 and try to mix in 93 to even it out, when was the last time you changed youre fuel filter? Spark plugs? Cleaned the throttle body? All this adds up. Im betting 80% if it's running real rough it might be a coil pack or spark plugs.
Its not the fuel. Your car wouldnt shake like that with bad fuel. What it would do is ping and smell like rotten eggs- and maybe not even that because our cars have a knock sensor. So you didnt do anything wrong.
I see you are new here. Is your service engine soon light on? If so, follow the procedure in the FYI to determine which code comes up.
I think you have a bad ignition coil pack. There's a way to test them. Its listed in the Haynes manual. Test them all. I think you have one that is bad.
Change your spark plugs while you are at it. Get NGK Copper or Platinum. Depending on your budget. I use Denso Iridium but they are $11 a plug. I absolutely love them. If you have the cash just get NGK Platinums.
If this doesnt work then remove all the coil packs and plugs. Take a paper towel and stuff a corner into each of the spark plug holes. Dont rip the paper so it goes into your engine.
Crank your engine a little. Now remove each paper towel and see if they all smell like fuel. You will get high but its worth it.
If one of them doesnt smell like fuel. Thats the one where your fuel injector is bad. Change that injector.
That should take care of your problem
thanks for your advice guys, this maxima is my daily driver that I dont like pouring too much $$ into (i got a c5 for that
). I use to use 90 octane gas everyday until the gas prices just went up $0.25 the last week, so i thought how bad could the 87 be you know?
The car drives if i force it, but its just shaking the whole time. I took it up to 40mph. And the Service Engine light isnt on.
What ive tried: I put octane booster and a gas treatment/fuel injector cleaner with about 5 gallons of 93 octane gas this morning.
Result: No changes.
I dropped it off at the mechanic to change the plugs/wires tomorrow morning.
Something that the corvette forum guys pointed out to me: the dealer says to use 87 octane or higher on the '05 maxima (not 91) and that "Most likely your knock sensor detecting ping and pulling back the timing."
). I use to use 90 octane gas everyday until the gas prices just went up $0.25 the last week, so i thought how bad could the 87 be you know? The car drives if i force it, but its just shaking the whole time. I took it up to 40mph. And the Service Engine light isnt on.
Result: No changes.
derekinthez
Nov 13, 2022 04:00 PM
sctludwig
Sep 1, 2022 01:32 PM
fastcarny
Oct 6, 2015 10:42 AM
sdotcarter
Sep 2, 2015 09:53 PM
Of course its gonna run different. You probably could use new plugs too
