Vibrating at speed
Old Mar 18, 2005 | 01:08 PM
4dscPat's Avatar
Vibrating at speed (edit: Wheel bearing?)
This didnt happen before I did my 5 speed swap. I replaced the left axle, but the right is origional as far as I know. Car has 140k on it.
It shakes at highway speeds. I can feel it with my feet through the floor, and the steering wheel shakes left/right. Whats wrong? I miss being able to cruise smoothly at 90 mph.
In case it matters, I didnt keep track of the left/right front wheels when I did the swap so they could be reversed for all I know.
Old Mar 18, 2005 | 01:12 PM
tripleGmax's Avatar
get it aligned??
Old Mar 18, 2005 | 01:59 PM
subs1000w's Avatar
could be axle problem but id get tires balenced
Old Mar 18, 2005 | 03:52 PM
avmaldo's Avatar
check your: control arm bushings and ball joints, motor mounts, tires, balance, alignment etc...
Old Mar 19, 2005 | 09:44 AM
4dscPat's Avatar
Took it to NTB for an alignment and wheel ballance,and they said it has a bad wheel bearing
Assuming I take the hub off the car myself and take it to a machine shop, how much should it cost for a new bearing + pressing it in?
Old Mar 19, 2005 | 09:59 AM
Wiking's Avatar
Call, ask. Their minimum charge is my bet.
Old Mar 19, 2005 | 10:46 AM
subs1000w's Avatar
go to autozone to get the bearing and i would recomend replacing both the iner and outer seal since they usually get damaged in the removal process
1 bearing 30$
2 seals 20$
labor maybe 50$?
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
uttadms31
Sep 30, 2015 05:24 AM
