help removing flashing air bag light
alright i'm sick and tired fo the damn light flashing at me allthe time. i tried resetting with turning onthe ignition and pressing the door switch 7 times. it work a couple of times and now it won't do it anymore. i took my dash apart and tried to take the light out but it's inside under the dials how do i remove the needle so i can slip the light out ? any suggestions.
How about trying to figure out whats wrong with it first? Or better yet, take it to a Nissan dealer and get it fixed under warranty.
*Edit n/m I guess Nissan's SRS is with the powertrain coverage, at least for my 1996 MY. My 00 had a 10year/unlimited mileage on the SRS.
If the light is on, then the airbags will not work if you have an accident. At least that's what the light means on my Mom's Subaru. We had the same problem so I would definitely recommend you have the dealer check it out. Airbags are not something you just want to ignore if there is a problem.
not tryin to jack the thread, but recently, only sometimes this happens, my airbag light will come on when i start up my car and it will make a beeping sound but doesnt blink. it then turns off after about 10 seconds. anyone know what this means?
well you should prob. take it in to get it checked out like others said, but to answer your question just follow these steps: http://www.geocities.com/amixam69/nissan/dash/
and just twist and remove the correct bulb from the rear side of the cluster
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
