Oil light when i slow down...is this a bad thing?
I know its not good that when i slow my car down the oil light comes on..what the hell could it be? its flickers when i slow down, and when i speed up again..its not on anymore...ay ideas?
i had the same thing.. i had a hole in my oil pump.. but start with the sending unit first its the cheapest to replace..and no it dosent mean your oil is low it means the oil pressure is to low..
Originally Posted by nismology
You have less than 2 quarts of oil in your car. Refill immediately.
It's the oil PRESSURE light... it means your oil pressure is too low. It's not an oil level light. But it can be triggered from having low oil pressure as a result of low oil quantity. It can also happen with the oil level totally normal.
This is the exact problem I'm having! I had a new water pump installed and when I got the car back it was doing this. I think my father put in some cheap oil. Could this cause the problem? I plan on changing the oil and oil filter tomorrow and putting in synthetic oil since I have like 165K miles on the car. Is using synthetic oil
a good idea?
a good idea?
well i changed the oil with synthetic oil today..the light seemed to stop turning on and off...ill keep you guys posted...and i also need to change some kind of switch which was moist when the went under to change the oil...ill let you know what happenes
just to let you know, its not good for your car if you switch off and on using synthetic and non-synthetic. once you go synthetic, keep it synthetic and nothing else. i've used Mobil 1 fully-synthetic on ALL my cars. But no, i don't get the stupid Mobil 1 fully synthetic for like 100,000 miles or something since there's not once SINGLE filter made to filter that kind of mileage
It is an oil pressure light but yes if your oil level is low it will give you the exact symptoms you received, becasue it's not ab;e to pump the volume of oil required, so when you brake or corner hard breifly starving the pump of oil the light flickers, changing or adding a quart should make it go away, if it doesn't you've got bigger problems.
Originally Posted by chuckie311
thats not true where did you come up with that from.. if you read the hayes repair book the oil light has nothing to do with your oil being low.. its a light for the oil pressure being to low..
BTW FSM>Haynes
ok..well its been 1 day..and everything seems to be fine...i got about 3.7 quarts when i drained the oil...2 days ago...dunno what it could of been except a need of an oil change.
I know this. What's your point? In 9/10 cases the light coming on means low engine oil since there's not sufficient oil to build pressure. It can also occur if the oil pump housing is cracked in half but that's highly unlikely.
BTW FSM>Haynes
BTW FSM>Haynes
BTW FSM>Haynes
BTW FSM>Haynes
no its does not if you know anything about the light its oil about you oil pressure being low. nothing to do with your oil being to low its an idiot light get the book and read it. its also can be the sending unit in the oiil pan also.yeah no kidding my oil pump was cracked in half
JMag90
Aug 25, 2015 09:17 AM
yat70458
Aug 3, 2015 01:16 PM
