My turbo install pics!!!!!!!!!
Old May 4, 2005 | 11:51 PM
96_vqmax's Avatar
My PFI turbo kit install pics!!!!!!!!!
Here's some pics of my turbo install,but not finish yet,got to go out of town for work,so will continue Sat.Enjoy!
Here's the pics of my 95 before(piece of ****,LOL).
http://memimage.cardomain.net/member...8_185_full.jpg
Here'a the pic of the bottom install.
Pic of upper oil pan tap.
http://memimage.cardomain.net/member...8_186_full.jpg
http://memimage.cardomain.net/member...8_189_full.jpg
http://memimage.cardomain.net/member...8_207_full.jpg
Here's the pic of engine before install,I know it's dirty,but I couldn't wait to put it on,LOL!
http://memimage.cardomain.net/member...8_191_full.jpg
Here's a pics of the after,much better looking is it,LOL!
http://memimage.cardomain.net/member...8_205_full.jpg
http://memimage.cardomain.net/member...8_202_full.jpg
http://memimage.cardomain.net/member...8_203_full.jpg
Here's the pic of the front mount intercooler.
http://memimage.cardomain.net/member...8_195_full.jpg
http://memimage.cardomain.net/member...8_196_full.jpg
http://memimage.cardomain.net/member...8_197_full.jpg
http://memimage.cardomain.net/member...8_200_full.jpg
Pic of poly engine mount.
http://memimage.cardomain.net/member...8_190_full.jpg
Old May 5, 2005 | 12:26 AM
Oblongshapes's Avatar
Nice man, I should be starting here in about 2 weeks. I have a couple questions..
When you put the bend in for the reverse y-pipe, did you use a full 180 bend, or more like a140 degree bend?
Whats the width of your intercooler? (i hope mine its too big after seeing yours)
Where did you buy up your oil pan bung?
Old May 5, 2005 | 12:33 AM
96_vqmax's Avatar
Thanx,well mine was the PFI kit.The pipe was a little bit off,but no sure how much the degree was,the oil pan bung come with the kit also,sorry I can't help you on that one.Maybe some plumming supply store might have it.
Old May 5, 2005 | 12:34 AM
96_vqmax's Avatar
Edited the title,sorry for the confusion.
Old May 5, 2005 | 12:54 AM
HNDA ETR's Avatar
Still Here... IM me for more..
nice job..
one thing though, in this pic: http://memimage.cardomain.net/member...8_203_full.jpg it looks like the intake pipe is resting on the turbo... hopefully that's not the case?
Old May 5, 2005 | 05:09 AM
I30tMikeD's Avatar
Sweet! Looks like it is comming together nicely. Brings back memories....keep us updated
Old May 5, 2005 | 06:21 AM
95turbo gxe's Avatar
Got that boost huh?
you will like
Old May 5, 2005 | 06:26 AM
stephenlc's Avatar
yeah frank why is the intake pipe resting on the turbo?
Also what did you do to the reverse y-pipe?
Old May 5, 2005 | 06:27 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Yeah definately need to move the piping over some, and the turbo so that they aren't so close - otherwise you're going to melt that silicon coupler.
Old May 5, 2005 | 06:30 AM
stephenlc's Avatar
man your oil return is really close to your O2 sensor, when the engine moves they might hit each other or is it just the perspective?
Old May 5, 2005 | 06:53 AM
I30tMikeD's Avatar
I have a silicone coupler just about touching my down pipe and there is no signs of any damage from the heat.
Old May 5, 2005 | 09:56 AM
Royal_T's Avatar
LookN good V6 VQmax, Every thing seems to be coming together smoothly, keep us posted once you get back. All this turbo talk gets me excited, I'm counting down the days i should get mine back.
have fun boostN
Old May 5, 2005 | 10:45 AM
choray911's Avatar
The Crazy Azz Cracka
The hose next to the turbo isn't a prob. Just trim a half inch of one of the ic pipes next to the radiator neck and you'll have the clearance. My return line rests on the o2 senser but you can get around that. Get an epoxy exhause fix kit ($5) and wrap it around the sensor. Then go to a race shop and get some insulated split loom and put it on the return line and zip tie it to the engine mount, crisis averted. Just make sure you don't have a kink in the line where it fits onto the nipple other wise to could blow out a seal on the turbo.
Old May 5, 2005 | 11:35 AM
subs1000w's Avatar
nice clean install
i like the idea of using split loom to protect the intercooler pipe that runs through the front clip
i was gona ask Y you biult a "reverse ypipe" but then read its a PFI kit
Old May 5, 2005 | 04:50 PM
Brad92SE's Avatar
Looks like it's coming along nicely! When you get done, enjoy it!
Old May 5, 2005 | 06:20 PM
Bags's Avatar
VG Ridah's Biatch Hoe
nice pics, keep us updated
Old May 5, 2005 | 07:53 PM
turbomax97's Avatar
Since the o2 sensor and the oil return are going to move independantly?... you realize all of it is bolted together right?...
Old May 5, 2005 | 11:22 PM
96_vqmax's Avatar
Originally Posted by HNDA ETR
nice job..
Thanx,well like I said I'm not finish yet,that pic I just lay it there and my friend took the pic.
Thanx Mike.
Thanx 93turbo gxe thanx.
spanishrice,well the y pipe come in two piece,that's the reverse y and another up pipe.yeah the oil rt was pretty close,but nothing is rubbing anything,just the way the pics look,the engine's not going to move now with the poly mount.
choray911,I know I trim some already,but need to trim some more,cause it's still rest on top of the upper radiator hose.But not touching the turbo,that pic was taking before I trim it,I'll take some new pics sat when I come back.
subs1000w,I like my thing nice and neat,no metal rubbing metal.I got that idea from the 18 wheeler,they used that split loom to protect everything,electric wire,air hose,fuel line and......
Old May 5, 2005 | 11:28 PM
96_vqmax's Avatar
Thanx,but your car look 100x better than mine on the outside right now,but maybe in a month or two I'll start on the outside like cefeiro black housing 1 piece headlight(I already got),97 rear conversion,OEM wood grain interior(I already got too)and a daytona 350Z blue.
Old May 5, 2005 | 11:33 PM
96_vqmax's Avatar
Thanx for the advice,so how your car doing after you fix your vaccum problem.
Old May 5, 2005 | 11:35 PM
96_vqmax's Avatar
have fun boostN
Thnax,I hope I can get her running this sat when I come back.
Old May 9, 2005 | 05:01 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
One other concern I've seen besides that intake piping being so close to the uncoated turbine is this pic...http://memimage.cardomain.net/member...8_196_full.jpg
You need to secure the IC(if you haven't) because this "notch" will allow the IC to move and it will keep pulling off your upper TB/pipe hose connector no matter how tight you make those T-clamps.
Others have just drilled through like on the drivers' side and not secured the IC without issues, but the one I've seen just like yours kept coming loose.
Old May 9, 2005 | 05:23 PM
I30tMikeD's Avatar
I agree it migh be a problem, but some metal straps can be used to keep the intercooler in place. I used two on each end bolted to the intercooler.
Old May 9, 2005 | 05:26 PM
IceY2K1's Avatar
Good idea Mike, however I doubt yours needed them since you drilled vs. "notched".
Old May 9, 2005 | 05:43 PM
I30tMikeD's Avatar
I didn't need for fear of seperating pipes, but my bumper cover curves down under the intercooler really snug and I knew I would hear it banging and vibrating against it if it was not "pulled" up just a tad and supported more. Without the straps I still had a good inch of wiggle.
Straps were not my idea. My brother used them on his interooler for his s13 and he got the idea from someone else.
Old May 10, 2005 | 06:43 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Ahhh the wonders of plumber's tape. Mike was yours galvanized? If not, you should probably spray some primer or clearcoat on them. You don't want to have rusty parts there.
Old May 10, 2005 | 08:44 AM
96_vqmax's Avatar
Yes sir,I bought some metal braket from muffler shop to make a bracket.
Old May 10, 2005 | 09:50 AM
IceY2K1's Avatar
Let me know how that turns out....
Old May 10, 2005 | 11:23 PM
96_vqmax's Avatar
HERE you go ICE.
Old May 10, 2005 | 11:37 PM
96_vqmax's Avatar
Here are some more pics I toke today.
Here's a pic of the fan shrout that I got to trim and modify the exhauste piping,just to get this little clearance,that's a 14mm socket.
http://memimage.cardomain.net/member...8_208_full.jpg
Here'a a 90 deg angle a got from HP for $2.00.
http://memimage.cardomain.net/member...8_209_full.jpg
Here's a view from under the front of the car.
http://memimage.cardomain.net/member...8_211_full.jpg
This is how the new charge pipe look like.
http://memimage.cardomain.net/member...8_212_full.jpg
Old May 11, 2005 | 05:58 AM
I30tMikeD's Avatar
Your feed and down pipe hug the transmission much better than mine. How much ground clearance are you losing....doesn't look like too much.
Old May 11, 2005 | 08:56 AM
96_vqmax's Avatar
Well maybe around 2"
Old May 11, 2005 | 04:24 PM
NOCturnalI30's Avatar
I did not realize how many of you guys are boosted. WOW did you all do these installs yourself?
Old May 11, 2005 | 05:12 PM
slimer's Avatar
some do, some dont. its just your familiarity with working with cars.
Old May 11, 2005 | 07:08 PM
I30tMikeD's Avatar
You better believe it
Old May 11, 2005 | 08:04 PM
slimer's Avatar
some people just show up for the first turn of the key
back on topic, since its the pfi kit, what sort of brackets does it come with.
Old May 11, 2005 | 09:25 PM
96_vqmax's Avatar
Well there is a long 90 deg bracket that weld onto the up pipe,that you bold onto the tranny housing,it's a pain to work on that pipe.
Old May 13, 2005 | 07:31 PM
Jar's Avatar
Jar
With the pfi kit I see the reverse Y pipe but does it still work with the rest of the existing exhaust? or did I miss that with the angle of the photo
Old May 13, 2005 | 07:51 PM
I30tMikeD's Avatar
Yes, the down pipe goes back under the tranny and connects to the cat.
Old Nov 22, 2005 | 10:03 PM
96_vqmax's Avatar
Update!
Sorry it's been a while seen I last update,cause I was pretty busy(plus short on ca$h)and only work on the car when I had time and doing most of the work myself,including a lot of body work,my friend help some and he painted the car,tell me what you guy think about the paint(350Z daytona blue),that's only buffing without the wax and all,LOL!
Here's a pics of before and after.
http://memimage.cardomain.net/member...8_234_full.jpg
http://memimage.cardomain.net/member...8_240_full.jpg
http://memimage.cardomain.net/member...8_239_full.jpg
http://memimage.cardomain.net/member...8_241_full.jpg
Here a few pics of the car.
http://memimage.cardomain.net/member...8_242_full.jpg
http://memimage.cardomain.net/member...8_244_full.jpg (you can see the reflection on the roof,LOL)
http://memimage.cardomain.net/member...8_243_full.jpg (yeah I know,it's a 95-6 tail with the 97-9 trunk,LOL,I try to order a set red and clear from redlinemax.com for a few week already,still can't get a set.You can see my reflection on the trunk too,LOL!)
PS:More update on the car's performance SOON,LOL!
