400cc injector install problems
Old May 7, 2005 | 01:37 PM
Oblongshapes's Avatar
I think I figured out the cause.... but here is the story.
I figured I would get all the preliminary stuff done before I turbocharge. Well, I put in the 300zx injectors and I noticed smoke coming out of the muffler. It was white so i knew it wasnt oil... As it ran longer fuel began dripping out of the exhaust and I cut the engine. I pulled off the upper intake again and noticed that one phelm had fuel lying on top of the valves. i thought maybe the 0-ring wasnt seated right so i changed the o ring and replaced (actually swapped a front one with the rear one incase it was a faulty injector).
Still the same problem... So i put the stock 3 back in the front and the smoke seemed less.
Im thinking that the 400cc with the walbro fuel pump is just delivering way too much fuel for the N/A engine. I guess I will just have to wait till Im actually turbo'ed to put these in.
Any one else ever try running the 400cc N/A and get white smoke and fuel drips?
Old May 7, 2005 | 02:04 PM
matty's Avatar
Well you got bad results with the 370cc Injectors and now you wanna go UP to 400cc ?? Am I missing something
-matt
Old May 7, 2005 | 02:13 PM
no they are 300zx injectors that flow 400
Old May 7, 2005 | 04:32 PM
chris'smax's Avatar
how are you controlling these injectors? Did you try lowering base FP?
Old May 7, 2005 | 05:01 PM
I30tMikeD's Avatar
Well, being NA and idling have nothing to do with each other. Even if you had a turbo installed, the car at idle is the same.
If you have not turned down base fuel pressure with an AFPR, have a walbro installed, and running an A32 MAF, then your dumping a tone of fuel.
I am also confuesed by your post. Your using a faulty injector? You put in 3 stock injectors and 3 400cc injectors? Please clairify.
Doing preliminary installs before the turbo goes on is a good idea. But that is for such things as the fuel pump, any guages, battery relocation. I would not have just installed 400cc injectors without any means to control them.
Old May 7, 2005 | 05:39 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
did you adjust base fp?
Old May 7, 2005 | 07:54 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Sounds like a bad o-ring, maybe it's torn.
I have 400 cc injectors in the car, 255 fuel pump, base FP, AND Z32 maf. Car runs fine. NA, BTW.
Old May 7, 2005 | 09:02 PM
95CustomMaxima's Avatar
Make sure you grease up the O-rings, use motor oil or such to grease them. Like Bags said it is probably a torn O-ring(s), hence the white smoke and the fuel out the exhaust. Check and grease the O-rings.
-Nick
kjlouis
Nov 24, 2018 06:09 AM
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
Slamrod
Sep 3, 2015 07:38 PM
kirkhilles
Aug 8, 2015 10:53 AM
