Heated Oxygen Sensor???
Old Jun 2, 2005 | 01:27 PM
shurik's Avatar
I've been running my car with SES light for a while and I found out it's P0138 Heated Oxygen Sensor (H02S) Circuit High Voltage Bank 1 Sensor 2. Can anyone tell me where that sensor is located . Pics of where it is would be very helpful or any kind of info. Thanks guys.
Old Jun 2, 2005 | 01:53 PM
Larrio's Avatar
The Definitive AE Master
bank 1 - rear manifold, sensor 2 - secondary o2. If you look underneath the valve cover on the front of your car after the radiator there are four plugs. The P0138 is the plug with the white harness. Follow that down to your o2 and you've got it
Old Jun 2, 2005 | 04:45 PM
shurik's Avatar
On my 02 Max there's no white harness. I see those four harnesses under the cover, but none of those are white, only one harness has white wire though. Perhaps on your 01 Max it's different.
Old Jun 2, 2005 | 07:25 PM
Larrio's Avatar
could you name the harness colors? i've worked on 2k2s and they are the same as mine
Old Jun 2, 2005 | 07:38 PM
shurik's Avatar
Here are the harness colors of the sensors.
Old Jun 2, 2005 | 07:58 PM
grey goose's Avatar
I think he meant the one with the white wire covering. I had a code p0140 and the stealership told me it would cost 540 to replace two sensors, the white wire and the red wire one. I did the parts myself and brought it to them for the ecu reburn. Total cost for me 280.
Old Jun 2, 2005 | 08:05 PM
shurik's Avatar
You mean you installed the parts by yourself, and $280 for the ecu reburn?
Old Jun 2, 2005 | 08:07 PM
grey goose's Avatar
the parts were 210 and the reburn was 70.I got the parts from autozone. the dealer wanted 180 a piece for each o2 sensor.
Old Jun 2, 2005 | 08:12 PM
shurik's Avatar
Man $70 bucks for the reburn. So do you have to reburn the ECU after you change the o2 sensor???
By the way did autozone had the sensors in stock or they had to order? cause our autozones doesn't have them and they could order $137 a piece.
Old Jun 2, 2005 | 08:17 PM
grey goose's Avatar
yeah that was their hourly labor charge.All they do is hook it up to the machine and take a coffee break. You could get lucky and change the sensor and reset the ses light if you have a scan tool.Nissan has a tsb out for my particular code, can't remember if yours applies too. I've had so many problems with the car I just wanted them to do reburn it so that if the ses was still on I could have b*tched them out about it. I did have to order the sensors. One was 90 and the other was 110 + 5% tax. It took about a week for the parts to come in. Just make sure you check they are the right ones cause the first time they one of the sensors I got was the wrong one. Three days later I got the right one and everything was fine after that.
Old Jun 2, 2005 | 08:23 PM
grey goose's Avatar
The link for the tsb is http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Old Jun 2, 2005 | 08:36 PM
shurik's Avatar
Thanks that might be helpful.
Old Jun 2, 2005 | 09:13 PM
scmaxima2k's Avatar
I have the same code right now as you, I got the sensors (I own an auto parts store so I got the 2 Bosch replacements which are the same as OE), but I wasn't going to do the ecu update, I was just gonna clear the CEL with my scan tool and be done with it, anyone know how important it is to reflash the ECU after replacing the sensors?
Old Jun 2, 2005 | 09:17 PM
remembermorriso's Avatar
sorry not to steal this thread, but thats my problem Im not an forum idiot but I cannot start a new thread. The message tells me I dont have the privalege.
just wondering why I cant
Thanks in advance...
Old Jun 2, 2005 | 09:53 PM
danger300z's Avatar
buy an universal O2 sensor , I did and it worked just fine for me !!!
Old Jun 3, 2005 | 04:19 AM
Epacy's Avatar
Unsuccesful STL Coordinator
I am not sure if you have to "re-burn" your cpu on 02+. Anyone know for sure?
And why are 02 sensors so damn expensive??
Old Jun 3, 2005 | 06:13 AM
Puppetmaster's Avatar
Ya need 15 posts.... http://forums.maxima.org/announcement.php?f=10
Old Jun 3, 2005 | 06:27 AM
Don't quote me on it, but I think in the past people have just swapped out O2 sensors, done the ECU reset procedure, and things have been fine... I THINK...
I'm sure someone with more technical expertise could verify this....
Old Jun 3, 2005 | 10:30 AM
shurik's Avatar
Larrio so the P0138 o2 sensor is the blue harness with white wire, right?
Old Jun 3, 2005 | 11:43 AM
shaunkey1's Avatar
yesterday when looking at the org i noticed there was a post about gas mileage and i have a 2000 max gle and i only drive city miles and from full to light turning on i was wondering how many miles i should get want to see if there is something wrong with the way i drive or something else
Old Jun 3, 2005 | 12:29 PM
Larrio's Avatar
yes
left to right
1: blue harness/ light blue plug - primary front bank (bank 2)
2: red harness/ green plug - secondary front bank (bank 2)
3: white harness/ dark blue plug - secondary rear bank (bank 1)
Old Jun 3, 2005 | 12:41 PM
Epacy's Avatar
Shoot I think I might have a problem with mine as well and if it is the blue one then that is hella close and fairly easy to get to.
Old Jun 3, 2005 | 02:28 PM
shurik's Avatar
Yeah stay below the 3000rpm and then see how many you'll get. Don't floor the pedal. By the way do you have SES light on, or not? If not then I guess slow down bro.
Old Jun 3, 2005 | 02:31 PM
shurik's Avatar
yes
left to right
Ok thanks a lot bro, then I'll try to get that one. I think it's like $137, kinda a lot.
Old Jun 3, 2005 | 02:45 PM
yes
left to right
And to add an FYI to what Larrio posted... this TSB:
It has diagrams of where all the O2 sensors are, bookmark or download it... its useful to have...
Old Jun 3, 2005 | 03:13 PM
dgmaxse's Avatar
also check this thread it may be helpful http://forums.maxima.org/showthread.php?t=405138
Oh, aren't you under warranty being your car is an 02
Old Jun 3, 2005 | 07:36 PM
danger300z's Avatar
yup thats true i did that and my car has been just fine
Old Jun 3, 2005 | 10:37 PM
vsamoylov
yeah i got the same code guys for p0138. i want to replace mine as well but i read that link from above and it says that both rear bank 1 and bank 2 should be replaced. or is it okay to change only one? and bank 1 is the blue connector and bank 2 is the green conector to the left of the blue connector right? how much are they each and if i buy them from nissan, are they going to fail on me again? thanks guys.
Old Jun 7, 2005 | 08:40 AM
shurik's Avatar
I think you need only one. I hope they will not fail us agian, cause I'm researching about these sensors before I get one. So far I'm going with OE type Walker. I think those are good.
Old Jun 7, 2005 | 11:14 AM
Epacy's Avatar
I just ordered one from Dave B. It comes with the connector and everything so no splicing!! Hopefully it won't be too much of a pain to replace.
Old Jun 7, 2005 | 01:17 PM
vsamoylov
how much did you pay for it?
Old Jun 7, 2005 | 01:29 PM
Epacy's Avatar
It was $108 shipped. And you do have to specify which one you need.
Larrio's Avatar
i just put the o2 sim in mine because the secondary one kept blowing up everytime I did a hard run (2nd and 3rd gear redline)
it was another excuse to convert to fed-spec also
Old Mar 4, 2007 | 06:15 AM
RBK's Avatar
RBK
I have to replace mine also and can not figure out the routing. I see it in the engine compartment and I see it where it plugs in on the exhaust pipe. From the exhaust pipe, it goes up thru the drivers side floor board. From that point, I can not tell how it routes. Can someone give me guidance? Do I have to remove carpet, etc.?
Old Mar 30, 2007 | 09:57 PM
DrunkieTheBear's Avatar
Turbo'd Saab
I had the p0140 and just replaced the white one I got the sensor for 60 and just installed it myself and then I had my friend do the ECU reprog and gave him a case of beer and all was good
Old Mar 31, 2007 | 10:21 AM
OOmaxSE's Avatar
Is it really necessary for a reprogram when you're replacing a faulty sensor? I think you can just plug and drive.
Old Mar 31, 2007 | 03:17 PM
CCS2k1Max's Avatar
It's not really necesary, but you'll be getting CELs more often due to "too narrow" response parameters.
Old Mar 31, 2007 | 03:18 PM
kenshi's Avatar
There's a TSB out there that calls for a reprogram if you pull certain o2 codes.
Old Apr 7, 2007 | 12:32 PM
Dave B's Avatar
Not DAVEB the parts guy
Hey guys, my friend has a 99.5 cali-spec I30 which has the exact 02 sensor layout as the 2000+ cali-spec Maximas. His car recently threw the P0138 code. My OBDII scanner said Bank 1, sensor 2. My question is exactly which sensor is this? Is it the sensor down at the Y-pipe junction right next to the crossmember (faces towards the front of the car, technically mounted downstream of the rear precat).
Old Apr 7, 2007 | 12:42 PM
kenshi's Avatar
^^^ Yep, that's it.
