02 sensor (0707) how to replace?
So i've got the code 0707. It says in my Haynes repair manual:
p0136.....0707....downstream oxygen sensor or circuit fault
I dont know what that means. Whats a circuit fault? anyway, i'm going to just pick up this sensor today and get it over with but i've got some questions
1-where is this located (pictures would be nice)
2-how do i replace it
3-is it before or after the catalytic converter (apparently this determines whether its 50 bucks or 90 bucks at o'reilly auto parts)
also, i read in the stickies that this sensor just "keeps tabs", so will it still improve gas economy or anything? I mean i'd hate to spend money and time on something that doesnt really have an effect, just because the EC light came on.
thanks guys.
thanks guys.
You said you have a Haynes manual. Why don't you use it? Your Haynes manual shows precisely where the downstrream 02 sensor is (see section 6-15, picture 12.6c).
It is located at the catalytic converter outlet. Instructions for replacement are provided.
It's at the end of the cat, closest to the muffler. I read recently that this 02 sensor does not affect fuel economy as the other two do. I'm not sure what the downside is to not replacing it or whether or not you can pass emissions without replacing it.
it donest do anything, ive had the code since i got the car over a year ago. im doing 26 mpg mixed, i was diong the same prior to the code as well. it must monitors if your Cat is functioning, but the cat has outlasted the sensor
mrc00l88
Jan 25, 2024 01:14 PM
Rage Maximus
Sep 3, 2015 12:26 PM
doobadoo
Aug 15, 2015 06:43 PM
