help fast! car dont wanna turn on cuz of cai
There are several hoses that you may be referring to:
1. the front valve cover breather hose
2. the hose from the intake to the IACV
3. the vaccum line from the intake
I think those are the only ones that you need to disconnect to pull the intake... which one are you talking about?
I think you need to post in the regional forums and get someone to come over and help you out - maybe for a small fee. Also, please stop typing like you are on a teen forum chatting with your friends. This is not an instant messaging forum.
i don't know if this be da tube they be talking bouts, but there be a tube runnin from da intake to da back of da mota, kinda beside da Throttle postioning sensor. Make sure that be hooked up dawg.
the blue circle is where the hose starts. Your intake might be different but make sure that hose is connect or the car alot of time will not start up. Make sure you Mass air flow seonsor is plugged in(but it should start without it being pluged in).
i do not care if she is girl i though i was a bad typer but that is just fu<king ridiculous.........
hwy would u wanna take ur car apart while installing a CIA?? =)) it took me about 1 hour to change mine with out any instruction. Seller even says, DO NOT INSTALL IT URSELF <i>UNLESS</i> U KNOW WHAT TO DO. any way, if u could post pix of what u've done, I'll help u
make sure all the clips are on tight. when i installed my CAI i had someone attach all the tubes with the clips back on for me.. i didn't know that the person was a reckless fool leaving one tube barely hanging on.. and after driving about 5 feet my car turned off because a hose blew off the piping it was supposed to be attached to due to pressure.
also if the "small tube" you're reffering to, make sure its on "tight"... i think i know what you're talking about and it takes a little force to get them back on.
- good luck.
- good luck.
Mooney
Originally Posted by rmurdoch
Duz da caw hav gas in da fewl tanq?
dat = That*
if a girl ever talked like *that* (dat (for You) ) in person, I believe it would be *the* (da) biggest turn-off .............ewwww
It sounds like you have down syndrom, or you sniffed a little too much TB cleaner while switching intakes
but all in all:
I hop u Hve Da best o luk trieing 2 fix dis prob mabe u shoud listen 2 Murdoch nd put some dat fewl n da tanq!!!
hahahahaha I couldn't help myself
Elmor da Fud
wow, you all must be big ballaz trying to hook up on the internet and all.....e-pimps!
Hell Yezzz
you wouldnt get it, it was an inside joke between my friend and I, I should have known you wouldn't get it
E-pimp? no
Pimp Yes
I dance like that guy in your Icon
What about posting a picture of the problem area and the hose in question?
