What size fuse?
Originally Posted by merovi
dont you just add up the amps on the fuses in the amps. Like if there are 2 25 amp fuses and 1 30 amp fuse, wouldn't u only need a 80 amp fuse?
The fuse in the power line is for the wire and should be based upon the maximum that wire can handle. The fuse on your amps are just that, for your amps. The maximum current draw for 4 gauge should be about 125 amps. I would suggest a 100 amp fuse, its fine to use a smaller one but definately wouldn't recommend going bigger than 125 amps.
knight_yyz
Nov 1, 2015 01:34 PM
