Tool Set for MAX
Tool Set for MAX
What's the best tool set I could get for tinkering my max? also will a 2-ton Jack be good enough to lift a 95 MAX off the ground and keep it off, or would it be best if I get a 3-ton?
-Dexter
-Dexter
1 ton = 1000 lbs
max weighs in at slightly over 3k for the intire thing, but your only lifting one end at a time so a 2ton jack is fine.
As for tool set, a variety of sizes of screw drivers both philips and flat head
a 10mm rachet....95 percent of the bolds on the max are 10mm
a metric tool set is basically the main thing you need
if you wanan spend the money a torque wrench, spring compressor, other things like that, a breaker bar helps but you can always just slip a pipe on the end of your wrench for that
I bought a 263 piece Craftsman toolset for $190 at Sears. It will have 99% of the tools I will ever need for this car. And get a 3 ton jack as they will, usually, raise the car higher. I have a 14" 2 1/4 ton and it does not have the vertical clearance I would like. So, I went out and bought a second, 3 ton jack that raises the car 21".
I actually recommended this one to Ty, though im not too fond of its tool "chest", you will need a universal socket and some extension bars. it was still an awesome deal. as for the 3 ton jack, no experience, but ill take his word for it.
Originally Posted by rmurdoch
The first tool you need is a Haynes manual. There is a section at the front suggesting what tools to get.
-Dexter
-Dexter
Originally Posted by adithius
Get snap-on tools if you want the best. $3,000 for a 148 peice set. Okay you probably dont need the best at $3,000, so a Craftsman tool set will do. Also get a 3 ton jack, you'll be glad you did.
-Dexter
Jump on ebay when looking for tools, you can find great used tools with lifetime warranty's for good prices. I went on a huge shopping spree today for tools since I just got a new job as an auto tech and spent a good penny. I bought a few new items from online retailers but most of what I got came from ebay. I picked up an Ingersoll Rand 2135TI 1/2" drive Titanium Impact Wrench (brannd new), some SK 1/2" drive 6point metric impact sockets 8mm-24mm standard sockets and 10mm-24mm deep sockets (all brand new), a variety of oil filter wrenches (brand new), Snap-on 1/4", 3/8" and 1/2" drive ratchets with snap-on 1/4" and 3/8" drive metric sockets (all used) (the SK impact sockets will serve a double purpose and be used on the 1/2" drive snap-on ratchet), a SK 1/2" drive micrometer torque wrench (brand new), SK 12" adjustable wrench (used), SK 18" breaker bar (brand new), Astro Pneumatic Plier Set (new), two magnetic mechanic's dishes (new), a SK 15 piece metric combination wrench set 8mm-22mm (new), and a 5 piece set of Witte Maxpro screwdrivers (new). I picked all of this up for about $930, and while it is still a ton of money, we're also talking about mostly SK and Snap-on tools here (Witte also makes some of the nicest screwdrivers you can buy), and if I was to buy all of these new off the truck I think I would easily be between the $1500 and $2000 mark. It was hard to find any used SK tools on ebay that I was looking for which is why I bought everything new from them minus the adjustable wrench, but used snap-on is always readily available and I think I got pretty good deals on the ratchets and socket sets considering their condition and what they normally sell for new. Sadly...I still need to get myself a toolbox. These guys better give me a raise in the near future after spending this kind of money in order to do my job! *sigh*
Craftsman would be best for quality and price.
Essential tools:
a good set of screwdrivers (phillips and flat)
a metric rachet & socket set with at least a 6" extension
a deep metric socket set for working on larger bolts in hard to reach spots
a breaker bar
a set of various type pliers
3 ton jack and jack stands
halogen light for working under the hood or under the car
(FYI, Most common size bolts on the maxima are 10mm, 12mm, and 17mm)
Essential tools:
a breaker bar
Essential tools:
a breaker bar
Essential tools:
a breaker bar
need:
pliers
breakerbar
won't get halogen because working at night on motor is a royal ***** anywayz
-Dexter
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
