SES light/No pressure in gas tank
Old Jul 1, 2005 | 03:01 PM
cwc412's Avatar
I checked the archives and can't find anything on this.
My SES light has been on for a little while. I ran the codes and it seemed to point to the EVAP cannister. I noticed a strong odour of gas one time and proceeded to remove the gas cap. When I unscrewed the cap, there wasn't a hissing noise. I decided to replace the cap with a new one and reset SES light. The light stayed off for a day and thene came back on. I checked the new gas cap and when I unscrewed it, the was no hissing noise. This leads me to believe that there is a leak in the system.
Any advice? Also, where is the EVAP cannister on a 2003?
Old Jul 1, 2005 | 03:21 PM
JUICED's Avatar
The EVAP canister should be located at the rear (drivers side) underneath the vehicle. I would perform an EVAP pressure test before changing any parts. When performing this test you can isolate which EVAP part is defective. BTW, exactly which DTC did you pull?
Old Jul 1, 2005 | 04:38 PM
hct67's Avatar
I have the same problem, mine comes on about once a week, I forget the code but its somkething with the fule tank.
Old Jul 1, 2005 | 11:58 PM
E55AMG2's Avatar
Wat
does the car perform differently in any way?
If not, then its just a ghost code....my car used to to the same thing and it just stopped one day. There is one thing you can do; cut the tie strap for the gas cap off and remove it from around the filler neck. If the CEL goes away, then you're set...if it doesnt, post the actual code and we will get to work on it.
Old Jul 2, 2005 | 06:08 PM
cwc412's Avatar
The codes I pulled are 455 and 1448. The car does run fine. Thanks in advance for your help.
Old Jul 2, 2005 | 06:14 PM
Mass_Media's Avatar
Mass_Media™
Mine would through that code when I first bought it....I was told that I needed to turn the gas cap 3 times after I fill up, no problems since....hope that helps....
Old Jul 2, 2005 | 09:12 PM
hct67's Avatar
The code I keep getting is P1456
Old Jul 3, 2005 | 10:18 AM
E55AMG2's Avatar
Wat
Your ecu thinks there is an evap leak....try cutting the gas cap retaining strap off and removing it from around the filler neck. Let me know what happens
Old Jul 3, 2005 | 10:22 AM
E55AMG2's Avatar
Wat
yours are the evap cannister vent control and evap control...try the gas cap thing i suggested. If that doesnt work...have the dealer perform an evap leak test.
Old Jul 4, 2005 | 07:02 AM
hct67's Avatar
Well, i took the restraining strap off and now will see how it works for the next week. The SES usually comes on once a week so i will have to wait. Thanks for the help!!!
Old Jul 4, 2005 | 03:37 PM
cwc412's Avatar
I've reset my SES light after filling up. I made damn sure I turned the cap through three clicks. I hope that SOB light never comes on again. I'll keep you posted.
By the way, no stopwatch is needed to reset SES light. Just count one one thousand, two one thousand>>>>>>>>>>>>>>>>>>>>>>>>....
Old Jul 13, 2005 | 04:37 PM
sosick's Avatar
my code came up as p0447
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
