How would you know if your flywheel is warped?
Old May 21, 2001 | 03:36 PM
JDwyer2821's Avatar
Old May 21, 2001 | 03:40 PM
Jeff92se's Avatar
I'm needing a caw
There are things to look for ie.. chattering clutch or odd clutch engagement. Why? Please list all of your concerns or symtoms at the same time please. thanks. All questions should be said at once also please thanks.
Old May 21, 2001 | 03:57 PM
JDwyer2821's Avatar
When the clutch is up it makes a clicking sound and get louder as I accelerate in 1st and 2nd. When the clutch is down It gets alot quieter but still there.
Old May 21, 2001 | 04:14 PM
Jeff92se's Avatar
I'm needing a caw
Not enough description for a good answer but it sounds like a throw out bearing. Search for more info on throw out bearings. Yes the tranny must be taken out to replace and it will cost at least a few hundred to change. Go ahead and replace the clutch and pressure plate and consider changing the rear main seal also.
Old May 21, 2001 | 04:20 PM
JDwyer2821's Avatar
I had all that done 700 miles ago. I now have a centerforce stage 1 clutch with a stock lightened flywheel. Also when I drop the clutch at 4000RPMs the car stays there intill I let off. the most I can drop my clutch at is 3200RPMs
Old May 21, 2001 | 04:24 PM
JDwyer2821's Avatar
Could this be the master clutch cyclinder? I think thats whats its called
Old May 21, 2001 | 04:29 PM
Jeff92se's Avatar
I'm needing a caw
Answering your questions is always the same : ) w/ bits and pieces of information. What do you mean car stays there? Tires spinning? Or nothing? If nothing(no tire spinning), that means your clutch is slipping. If you do this too much or if you do this before the clutch is broken in, you gonna end up w/ a glazed flywheel and maybe a warped flywheel. If the clutch is intalled correctly, you should be lighting up the tires. I can do burnouts w/ my lightened flywheel and stock Nissan clutch set-up. Is yours installed correctly? Did you break it in properly?
KabirUTA13
19
Oct 17, 2015 02:15 AM
raffivegas
Aug 23, 2015 09:54 PM
RealityCheck
Aug 5, 2015 06:18 AM
