HID Projectors as fog lights
Old Jul 13, 2005 | 09:22 AM
BudVlad's Avatar
Did anybody install projectors as fog lights?
How did you attach them?
Old Jul 13, 2005 | 12:08 PM
chr0nos's Avatar
i think you need a reflector for projector lenses to work. the lens itself loox about as big as the oem fog light. i dont think it would work.
Old Jul 14, 2005 | 03:15 AM
BudVlad's Avatar
The projectors have build-in reflectors. It will work! The question is how to attach it to the original plastic housing.
Old Jul 14, 2005 | 05:29 AM
2kprlmax's Avatar
pm Dr.Roy he has projectors in his fog lights.
Old Jul 14, 2005 | 10:57 AM
ColdSHO's Avatar
hope u got a dremel!
Old Jul 15, 2005 | 01:33 AM
OhOhMax's Avatar
I saw this thread yesterday and have been looking for a nice set of projectors ever since. It would not be hard at all to make it work. I just can't find anything that I like in a good price range >$500. This is deffinately something that I want to do. Whenever I can get ahold of a nice set of projectors I am going to make a wite up with pics as to how I did it. But I don't see it happening any time soon, unless maybe I can find something on ebay, haha.
Old Jul 15, 2005 | 01:37 PM
Yaco_Max's Avatar
Bosch Mini H3 Projectors:
Another exclusive from HiDPlanet.com! 1.5" Bosch Mini Halogen Projectors (H3) are the perfect solution for driving lights to compliment your H.I.D. or for standalone use. These units are perfect for any project and their compact size will fit just about anywhere!
Bosch Mini Projectors provide a super sharp flat cutoff for foul weather conditions. Each pair comes with H3 bulbs.
Bosch Mini H3 Projector Dimensions:
Max Outer Diameter = 2 3/4"
Lens Diameter = 1 1/2"
Max depth = 3 3/4"
Old Jul 15, 2005 | 04:17 PM
5 spd's Avatar
off topic, I have a set of is300 foglight projectors. I disassembled the foglight assemblies to get to these... I have no use for them
Old Jul 16, 2005 | 08:20 AM
nissan5788's Avatar
The Bosch have to be retro'd also..not an option for this guy b/c he already has projectors.
I just bought those projectors and will try to retro them into my PIAAs.
Old Jul 16, 2005 | 10:05 AM
BudVlad's Avatar
This is how I attached the projector to the fog light housing. I couldn’t figure out how to make it adjustable. The projector is too wide for the swing points in the housing. I will post more pictures when I am done.
Old Jul 16, 2005 | 10:29 AM
chr0nos's Avatar
what does retro(fitting) mean exaclty?
Old Jul 16, 2005 | 12:33 PM
lex3015's Avatar
I'm anxious to see how this finished up...I might try and do the same.
Old Jul 16, 2005 | 12:51 PM
Progress's Avatar
It's business time.
In our case it means cutting and installing. Basically, changing something to fit another part for installation. It's rather broad.
Old Jul 16, 2005 | 01:00 PM
Dr. Roy's Avatar
that projector is going to be to far foward, you probably are goin to want to set it back some. you can do this my moding the projector.
drill holes where the yellow lines are in the pic (all 4) and use some self tapping screws or whatever you have to secure the lens holder tho the reflector.
then use a hacksaw or whatever to cutt of the tabs (red line) that are used to secure the bezel/lens.
the tabs on the bezels can be secure under the screws you just added or just siliconed on since you will need to weather proof the projector anyway. you will also need to silicone where the lens holder and reflector meet and the bulb sits in its holder. dont need much but it needs to be sealed.
once you have the projector taken care of you will also need to cutt off the piece of plastic that goes acoss the opening in the back where the foglights sit so the back of the projector will fit
Old Jul 16, 2005 | 11:46 PM
BudVlad's Avatar
Thank you for the advice. I will try to do that.
Old Jul 17, 2005 | 09:15 AM
Ammi's Avatar
350 Detroit Muscle
subscribing
Old Jul 17, 2005 | 10:47 AM
ColdSHO's Avatar
why not take ur stock foglight and cut it apart and monuth the projecotr inside, even if u cut most of the old one away ud still have the stock mounting pionts most likely
Old Jul 17, 2005 | 12:09 PM
BudVlad's Avatar
The projector (left over from headlight retrofit) will not fit inside the original fog light. That would be too easy.
Old Jul 17, 2005 | 12:20 PM
BudVlad's Avatar
Finally finished!
I didn’t have to do anything drastic, I just filed a little bit from the side.
I had to cut the back piece and little on the side.
The projector fits nicely.
This is where I put the igniter.
Ballasts
Old Jul 17, 2005 | 12:25 PM
BudVlad's Avatar
Finished product:
Old Jul 17, 2005 | 12:39 PM
neroup5's Avatar
Looks great. How much did this project cost you?
Old Jul 17, 2005 | 01:22 PM
Chemsol's Avatar
subscribing
Old Jul 17, 2005 | 03:17 PM
ColdSHO's Avatar
friggin awesome, im working on a custom projecter fogs on my other car, but that cars easy casue the bumpers right behind it and i can just screw into it, u got skills!
Old Jul 17, 2005 | 04:00 PM
JKiMaxAC's Avatar
lenses
nice retro. but aren't your worried about the lenses?? what kind of projectors are they?? i'm not to sure if they make plastic projector lenses. but if there nice projectors i would make some type of cover or some thing.
other then that looks great.. post some pics of the beam pattern are they e-code or DOT?
Old Jul 17, 2005 | 07:42 PM
rmh3093's Avatar
Only gentoo powered Maxima!
yeah those look awsome, i hope the hold up to all the rocks etc. from the road
Old Jul 17, 2005 | 07:59 PM
chr0nos's Avatar
those look awsome! what kind of projectors are they, and where did you get them? also are you going to put some kind of protective lens (cover?) in front to keep the projector lens from getting damage by rock chips and such?
can you post pix of how this loox at night, i think we are all interested in the acutal light output.
Old Jul 17, 2005 | 11:43 PM
BudVlad's Avatar
It didn’t cost any $$. The projectors are left over from retrofit of my head lights when I replaced them with Bosch projectors. The beam pattern isn't so great (that’s why I replaced them with Bosch) but as fog lights they will do. I will show the beam pattern later.
Old Jul 18, 2005 | 01:18 AM
ChromeSE5's Avatar
will you put something over the lense to protect it?
Old Jul 18, 2005 | 11:34 AM
BudVlad's Avatar
The lenses are from thick glass. I would have to be large stone to brake it.
Old Jul 18, 2005 | 11:52 AM
lex3015's Avatar
Please post some pics at night with them on, I really want to see if this project is really worth it.
Old Jul 18, 2005 | 12:11 PM
BudVlad's Avatar
We have a heavy rain now. I will make some pictures when the rain stops.
Old Jul 18, 2005 | 12:33 PM
2kprlmax's Avatar
not for nothing, but there is no protection on the projectors. You will have problems with pebbles and stuff hitting that lens.
Old Jul 18, 2005 | 12:58 PM
icelandmaxima's Avatar
Maxima Fanatic
eager to see some night shots.
Old Jul 18, 2005 | 01:17 PM
MaximusMorpheus's Avatar
I wanna see the pics when they are up....
Old Jul 19, 2005 | 03:17 PM
BudVlad's Avatar
I finally tuck some pictures:
Old Jul 19, 2005 | 04:35 PM
JKiMaxAC's Avatar
what kind of projectors are they?? the light is chopped up and scatterd every where.. massive lose of light (do your projectors have a sheild?) .
Old Jul 19, 2005 | 05:52 PM
ChromeSE5's Avatar
they are the depo projectors, made crappy by having a very square reflector. They are fine for fogs though since most of your light should be coming from the main projectors anyways.
Old Jul 19, 2005 | 07:24 PM
dominican254's Avatar
First of all the custom work looks great. But why would u use the projectors from the ebay headlites. i Think it'll look mad nice if you had some e46 single xenons. But from the looks of it seems to work so i guess if thas what you want. Again the custom work is tight ive never seen that on a maxima till now
Old Jul 19, 2005 | 10:46 PM
BudVlad's Avatar
Why would I use the projector from ebay headlights?
Because I had no other use for them after I did the Bosch retrofit. I knew the beam pattern will be lousy but it’s still better than the original foglights.
Old Jul 20, 2005 | 06:17 AM
chr0nos's Avatar
i want to try this mod with the e46 projectors everyone is talking about. i assume they are of high quality, and good light output. are you guys talking about he actual BMW made projectors, or immitations that are made to look like bmw oem stuff?
how much were your boshc projectors, and do you think those would be a good candidate for the fogs?
