6spd on a 3.5L in a 4th gen
Anyone put a 6spd on a 3.5L in a 4th Gen? Of course it bolts right up to the engine, but is there space for it? Mounts? Any custom fabbing neccessary?
Well there's been cases of the 6-speed connected to the VQ30, and that's the same block, so I'd assume there's space.
NMex, I'm not trying to be an @$$, I'm seriously asking you why would the 5-speed be more effecient when attached to a VQ35?
Go to www.howstuffworks.com and look up manual transmissions. They'll show you how in a manual transmission, all gears are always connected and always turning -- the gear selector just chooses which one the input shaft is connected to. More gears means more stuff that has to turn in the transmission, and that means more power loss.
Originally Posted by d00df00d
The 5spd is more efficient because it just has fewer moving parts, and that means it transfers the engine's power to the wheels better. Its ratios are virtually the same as the first 5 gears on the 6spd, and same goes for the final drivev, so the 6spd doesn't have any advantage in gearing (except for cruising at highway speeds). The 5spd is lighter than the 6spd too, which of course helps things as well.
yes i have the 6 speed tranny connected to the vq35. the tranny mount is the only thing that you have to mess with. you see on the 4th gen that are 5 speed, the tranny mount is welded to frame just like the engine mount on the passengers side. so basically it is the same mount on both the passengers side and drivers side. now on the 5.5 gen that have the 6 speed, the mount is different. the mount is bolted to the frame with 2 bolts. so basically what i did was cut the spot welds on the old mount and grind everything down. then i sprayed the bare metal so it wouldnt rust. drilled the holes for the bolts and bolted the mount down to the frame. that is all that is involved. everything else is the same.
now about the 5 speed, yes it is lighter and yes there is less moving parts in it and yes there will be a difference in performance between the two but that difference is going to be so small that to me it wasnt worth putting a 5 speed in. i do alot of highway driving so a 6 speed was a plus for me.
Personally I do a lot of highway cruising too, so I wouldn't be interested in that...but it was just an idea for overcoming the inefficiency of the 6spd and maybe using a little more of its potential.
Originally Posted by MaxKlinger
Just a quick thought, are there any final drive re-gear kits for the 6-spd? If such a kit was available, might it be more advantageous to use the 6 spd for racing because you'd be able to actually use all the gears?
You can't just throw a 6 speed into a 4th gen and call it a day. Only a few people have done it and they'll all tell you how much of a PITA it really is.
Donate and search, all of these questions have been specifically answered before.
The 6 speed is less efficient than the 'old' 5 speed because it has slightly larger gears and it has 8 pairs of constantly meshing gears as opposed to the old 5 speeds 5 pairs (not including the final drive).
MAXSE5SPD
Sep 17, 2022 04:00 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
JoshG
51
Sep 21, 2015 10:41 PM
Violator
Sep 9, 2015 10:14 AM
