clearing an intermitent check engine light
my check engine liht was on in my 98, checked the code, 0304, which is the knock sensor, i reset it jut in case it was a one time thing and the light came back on. problem is that it flashes eratically depending on engine speed. is that normal? under heavy accel( not all the way) it stays off until 30-40, and it stays off when coasting until i stop. what i also found strange is that any time i key over the car now( not start it) it goes into diag mode and displays the code again. is that normal? i turned the screw back counterclockwise. i also cheked the resistance at both pins leading to the knock sensor and they are both out of limit, so i assume the knock sensor is no good. i'll change it and try again, but my biggest concern is that the check engine light is eratic like that.
ps has anyone replaced the knock w/o removing the intake. it looks possible. but my hands are big, lol.
Holy moly 1736 posts - where have you been?
1. the CEL will not light for just the knock sensor - you have at least one or more codes stored
2. the flashing CEL while driving indicates misfires... check the codes again or have autozone pull them for free and look up all the codes that are found.
3. the KS can be replaced without pulling the intake manifold off - look in the stickies for the howtos.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Didnt even see the 98 part in his post... Got too focused on the sig pic.
