Rust build up on caliper?
My rear driver side rotor is building up rust (on the part where the caliper touches).. my mechanic just showed me when he was changing my oil. He's saying I should probably replace my "loaded" calipers, then resurface the rotors. The problem is his estimate is $370 + $105 labor for the calipers. Christ, are they really that expensive?
He mentioned something about the calipers may be sticking, hence why I have rust buildup on the caliper. Do you guys think the rust on the rotor was caused by a sticky caliper? I do not beleive I've felt any problems with my brakes.. He said he can take a closer look if he does a brake inspection, but that will just rack up the $$, when there may not even be a serious problem.
Thanks.
Dan
Thanks.
Dan
If the rotor is rusting where the pad would normally be in contact with it, then yes you have either a seized caliper or the pad is stuck in the retaining clips and not making good contact with the rotor.
No way to tell without taking it apart. If you are a DIY'er, you can get rear calipers for 70 bucks a side and some new pads for 50 bucks, so for $190, you'll have new rear brakes.
You should also make sure your parking brake cables are engaging/disengaging as designed. They have a tendency to seize over time.
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
