hi-flow cat or test pipe?
Depends on budget and sound.
louder? = Test Pipe
Cheaper? = Test Pipe
Less Environmentally sounds = Test Pipe.
I say high flow cat. Heard decent thigns about stillen's high flow cat (~$250)
louder? = Test Pipe
Custom Enterprise has a high flow cat for $150..doubt its stainless, but its an option. You might even get better performance with it. A test pipe would be way too loud under the cabin, anyways.
My cat also needs replacement. Im going with a hi-flow for 2 reasons over the test pipe. 1 I dont want to be putting in a cat each time i have to do emmissions, as the gains from hi-flow vs test pipe are, as nmexmax said, "minimal .... if any". And 2 im getting a hi-flow cat in exchange for an axe, which i found for free, and stock orange corners. (Long story on that) Anyways, if i was u id go with a hi-flow cat as well.
Dont go with a test pipe, they sound like **** and do nothing. Get a hi-flo from warpspeed for $100, I have one and have no problems. The sound of the exhaust didnt really change. The only reason I got it was because my cat was bad, infact that is the only reason you should get one, they give no gains.
and i thought the gain of the hiflow cat was minimal. it sounds like your saying the DIFFERENCE between the test pipe and the hiflow cat are minimal.
Originally Posted by Shady33e
well its kinda hard to ask you since u had a bad cat, but so do I. Did you notice any gains, and is the sound clean.
You can not pass emissions with test pipe, but you cna pass with a hi-flow.
I say OEM cat. Unless your cat really need to be replace. I have a test pipe right now because my stock cat was clogged up, had a opening size of a nickel. What do I think? I don't like it. Don't replace your cat unless you have to. I'm looking for either OEM cat right now, might just go ahead and go with a brand new OEM cat. Anyone know if muffler shops carry OEM type cats?
Originally Posted by MDeezy
You finally put the clears on
Cumalot: the difference between OEM and hi-flow is negligible. Do you have any idea how much an OEM cat costs form the dealer? Its a few hundred bucks. If you need a new cat, a hi-flow is the best way to go. Its cheapper than OEM, it barely changes the sound if at all, it will still pass emissions, and it might add some slight HP.
I think his car was one of the few that actually looked good with the ambers on.
Originally Posted by chillin014
lol an axe.
Both sentences hold true no matter how u look at it. The differnce from OEM to hi-flow is minimal as well as hi-flow to test pipe. Main reason to get a hi-flow is because its cheaper then the OEM, and yet still has the same effect for emmissions as the OEM cat, where as the test pipe will fail.
well put.
You know you want to get it. . . . . . . . . .
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
i have the CM resonated test pipe. i got HUGE pop and rasps but it was b/c i didn't make everything flushed. after i spent about 2hrs carefully reinstalling it, it went away. sounds fine
I may have been on this site for a long time but dont invest a lot of my time on the site. It doesn't hurt to ask fellow org member who have diff things. I of coarse don't have a lot of money to say "Hey I tested every intake/exhaust setup". This is why we have forums to ask.
not worth the money for a test pipe unless youre going FI or you just dont want to pass smog. if youre thinking about a hi-flow cat, get one only to replace a bad stock cat. other than that its a waste of money.
Originally Posted by SMX95
With my random tech, when I went for inspection 3 months ago with a greedy exhaust/ stillen y-pipe I passed emissions. Nox was a bit high but the kid who did it ran it in 1st gear.
