EGR valve location & Cleaning?
Originally Posted by BewstAdd1ct
and so do many fords, as well as all late model water cooled Porsches and just about every engine with variable valve timing...
All of Toyota's VVTi cars (as far as I know) use valve overlap instead of conventional EGR systems, but some Nissan engines with CVTC (like the QG series) had traditional EGR systems until very recently (half way through 2003). Some of Mitsubishi's MIVEC-equipped cars (like the Galant) had conventional EGR systems until just recently too (I don't know if they still do or not). I'm sure there are other cars with variable valve timing and conventional EGR systems, but I'm too lazy to go Googling the issue.
I will admit that conventional EGR systems on cars with variable valve timing is becoming less and less common. In a few years, your statement will be very true.
Originally Posted by spiromax
Many new engines with variable valve timing do away with traditional EGR systems, but you can't really say "just about every engine with variable valve timing..."
All of Toyota's VVTi cars (as far as I know) use valve overlap instead of conventional EGR systems, but some Nissan engines with CVTC (like the QG series) had traditional EGR systems until very recently (half way through 2003). Some of Mitsubishi's MIVEC-equipped cars (like the Galant and 626) had conventional EGR systems until just recently too (I don't know if they still do or not). I'm sure there are other cars with variable valve timing and conventional EGR systems, but I'm too lazy to go Googling the issue.
for every one engine that has control of the phasing of the exhaust cam, and STILL uses an EGR valve you can come up with, i can point out TWO that dont...
03VQMAX
Sep 5, 2015 03:47 PM
