I can see !!!!
Old Sep 12, 2005 | 10:46 PM
Sterling2000's Avatar
I can see !!!!
I recently installed the projector headlights on my 00 and of course was unable to see anything on the road (I know, I know... no flaming necessary). So I came up with a solution (cheaper than HIDs), aim the highs down a little and make all four come on at the same time. It actually allows a reasonable amount of visibility and it was damn near free
Lights:
Halos:
Low Beams:
High Beams (All On):
Woo-Hoo!!!
Old Sep 12, 2005 | 10:55 PM
lex3015's Avatar
you should post a pic that shows the beam pattern with them all on
Old Sep 12, 2005 | 11:08 PM
n3985's Avatar
大陆弟弟
Won't you get flashed all the time even if they are aimed down? And the GB for Helios/Proumen HIDs are really cheap right now in the GB forum.
Old Sep 13, 2005 | 04:42 AM
crazy russian's Avatar
did you have to take the bumper off to install them? I was thinking about getting them. But i dont want to spend all day installing it. Does anyone have instructions on how to?
Old Sep 13, 2005 | 05:07 AM
Two 10mm bolts, wire the Halos to the Park Lights, Plug in the two harnesses, put bolts back in.......... Took 20 minutes to install both.
Old Sep 13, 2005 | 05:55 AM
NismoMaxm's Avatar
I like the look of those lights man and did the halos come with those projectors from customenterprise??
Old Sep 13, 2005 | 08:54 AM
Iron Scimitar's Avatar
Tha Snatcher
beam pattern pics would be nice.
Old Sep 13, 2005 | 09:44 AM
Progress's Avatar
It's business time.
You are also running illegal without hi-beams.
Old Sep 13, 2005 | 05:27 PM
BewstAdd1ct's Avatar
only in some states
Old Sep 13, 2005 | 08:04 PM
Not in Texas... I'm a state inspector here. High Beams must be present and operable but there is no standard for their "aim"
Old Sep 13, 2005 | 08:06 PM
Yessum they did
I'll see what i can do
Old Sep 16, 2005 | 01:32 PM
deftpunk's Avatar
beam pattern pics please.......
May not be for everyone but hey, you had a problem, came up with a fix and worked it out. Good work.
Old Oct 16, 2008 | 01:00 PM
cajun1104's Avatar
how did you do this
Hey sterling. sweet setup. i have the same type of lights as you do. i was trying to get all four on with the high beam because of the same problem of not being able to see. will you let me know how you wired that up for the four lights on?
thanks
Old Oct 16, 2008 | 01:24 PM
DrunkieTheBear's Avatar
Turbo'd Saab
thanks
Take the ground from the low beam and ground it to the chasis.
Old Oct 16, 2008 | 01:26 PM
SoonerFan's Avatar
Cletus
Originally Posted by BewstAdd1ct
only in some states
lighting laws are federal...not state
Old Oct 16, 2008 | 01:27 PM
SoonerFan's Avatar
Cletus
thanks
and why did you bump this
PM the man
Old Oct 17, 2008 | 12:36 PM
stocked out max's Avatar
if i only had a dime for every time you asked a noob about a bump
Old Oct 17, 2008 | 08:26 PM
Maxgig's Avatar
Then you'd have a bag full of dimes. But come on stocked out, this thread is over 3 yrs old, don't you think a pm would have worked better?
