A Hiss Noise comes from the Rear end of my ride
As the title states, theres a hiss comming from my car.
-When the key is off, there is no noise.
-When the key is in acc no noise.
-When the key is in on position, no noise
-when the car is running, there is a hissing sound noise comming from around the rear axel.
Based on what has been said, its not my tires or shocks. I have also heard that your fuel pump continues to run for 5 secs AFTER your car has been turned off. Is this True?? because if it is, my fuel pump is out of the question because the noise stops the second the car is off. I THINK I have noticed my car going through the gas rather fast..... I am going to raise it on a hoist today and look underneath.... Any Ideas????
I've never heard a fuel pump running 5 sec after being turned off. I say fuel pump. I can't really see EVAP having enough pressure to hiss all the time like that (and only when on). Not to mention, if it were an evap fault, you'd most likely have a CEL. The ECU does monitor EVAP function.
Trav
Trav
Trav
Trav
There is no CEL on. The noise starts Instantly. The second I turn the car on, It does not matter if the engine is hot ot cold. I THINK (hard to tell) the noise increases , if I increase the throttle. (gas petal).
I Will check the gas cap after work here, because I did fill the tank, then noticed the problem later that night.
I have the same problem now, an 01-11 code just randomly popped up on my car and I have no idea whats wrong. From what I have read, the EVAP system is jhust another emissions controll system right? So driving with one that has a problem wont cause any other problems right?
haha, oops, I am confusing two different threads, I thought the original poster said he had a CEL. nm.
edit: when you have an exhaust leak, your exhaust usually gets louder, it wont just start hissing. if you ever bolt on a new cat or something and dont use gaskets, youll see what I mean.
Huttig2009
Sep 25, 2015 03:31 PM
wingsfan24
Aug 15, 2015 07:35 PM
