My Max becomes loud
Old May 28, 2001 | 04:20 PM
hclll's Avatar
It seems some belt is making the noise when idling. Any idea? Which one should I check for crack?
Old May 28, 2001 | 04:26 PM
The Flem's Avatar
Its a serpentine belt, correct? yes, check for cracks, if it doesnt look shiny and new, replace it. Otherwise, crank down on the tensioner.
if its a vg motor I understand that it controls timing too. Hopefully somoeone else will tell you what to do to make sure timing is back to spec.
Old May 29, 2001 | 09:41 AM
David's Avatar
What's the noise?
If it's squealy, it's probably one of the external alternator / aircon etc belts, rather than the timing belt- I doubt that would make much noise. It'll be either OK or broken, in which case, you'll be climbing trees to collect your valves.
Back to the easier belts. Run the engine for a bit with squealing noises. Switch off. See which belt burns your (or better still, your assistant's) hand the worst. That'll be your bwoy right there.
Visual checks are easy. Do the belts look new, or old and crappy? Shiny on the inside is bad.
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
