I got Water in my TB
I drove through a large puddle of water tonight and my car stalled out. I had to push my car out of the water which was up to my shins.
I opened up the CAI at the TB to try and start the car. That didn't work. There was a little bit of water at the throttle plate, and it looked like some might have gotten behind it.
My car still wont start and I was wondering if this has happened to any of you?
sorry to hear about that. looks like your CAI sucked in some water thru the puddle you drove in, made its way into your motor and caused it to hydrolock. Start thinking about a VQ swap w/ lower miles
aaww fawk, i still dont understand why ppl put cai on there car, so much loss of low end, and the trouble you go threw, your better of staying short ram or hai, but ppl dont understand.
neways sorry to get off topic, but ppl read about driving in puddles with cai, but still ppl take the chance and leave the cai on there car.
neways bro im sorry to hear, more than likey your motor is hydrolocked, and you probably bent up all your connecting rods, especially if u had water near your tb
Originally Posted by staytuned24
this hapened to me just take out the plugs and crank the water out of it you might have water in the oil and the back of the intake. my car is still runing strong after this happened to me so you might be in luck
How would I crank it out? Do I have to take off my intake runners?
I had some water in my other car. We dried it out by stuffing a rag down each spark hole, and cranked for a few seconds. The point is, hopefully you'll soak up some of the water as the pistons shoot up. Be careful not to suck the rag in! Also, don't crank so much you drain the battery or kill the starter.
Jae
Jae
The motor will be fine. Just crank it without the sparkers and let everything dry out. Also change your oil since you prolly got water in there too. I'm speaking from experience since this happened to me a couple months back.
And to all the misinformed people that said your motor hydrolocked, it wouldn't even be able to crank if that was the case. It would literally be "locked".
When I tried to crank it over, the lights dimmed and it maid a single click noise. Each time only one click sound. It never actually turned over, it felt like it was about to turn but then it stops, and the click sound happens instantly.
I would try to turn the motor over "by hand" to eliminate the starting system as the culprit. You can do that by putting a 21mm socket IIRC on the crank pulley bolt and ratchet it clockwise. If you can't ratchet it, then the motor really IS hydrolocked.
BTW. Next time you try to crank your car make sure it's with the spark plugs removed.
I have my maf disconnected, will that affect the crank?
I also checked the oil with the dipstick and there were a few beads of water on the stick above the H mark. I dipped it again and there were fewer beads. I think I will have to take the plugs out now.
I also checked the oil with the dipstick and there were a few beads of water on the stick. I dipped it again and there were fewer beads. I think I will have to take the plugs out now.
Yea. As long as you don't forget that there's no oil in the motor next time you crank it.
I am really worried that this is going to be a motor replacement.
Now that i think about it, i suggest you wait til you can remove the spark plugs to crank the motor. For your starter's sake...
But yea, drain the oil. Let it drain as long as possible so as much water as possible can come out.
Originally Posted by maxhead
Go with all the stuff people said on this thread. But, if you've been trying to crank it for a while, and now your lights dimmed with a single click, your battery might be worn down. (Car does the same thing when the battery is weak.) Do all the other stuff, but check your battery (or get a jump) to see if it cranks to eliminate the starting system as a culprit (easier than manual cranking).
Originally Posted by 96blackmaxSE
why did u go through a puddle that was up to your shins?
was it an accident or what? it sounds like you drove through a creek.
Damn Darrius, I hope it works out alright. If you get it running again you better get yourself one of those CAI bypass valve things so this doesn't happen again.....Good luck man
I'm gonna go with the short ram style next time. We'll see how it turns out.
RWCreative
Sep 21, 2015 11:01 AM
dont try to start it for a day.. let the water dry out
