Dumb Mevi Question
Old Oct 10, 2005 | 11:35 AM
tuko's Avatar
Dumb Mevi Question
Does the Mevi help only on 5spd or does it help on automatics as well.
Old Oct 10, 2005 | 11:40 AM
mzmtg's Avatar
Minister of Silly Walks
It only helps 7 speed semi-automatics with a clutch.
Old Oct 10, 2005 | 11:44 AM
bigtimber's Avatar
If I'm not mistaken, they work even better on autos
Old Oct 10, 2005 | 11:49 AM
tuko's Avatar
I thought it produced better results on a 5 spd.
Old Oct 10, 2005 | 11:59 AM
2 Da Max's Avatar
works better on 5spd, the auto shifts too quick so you cant really take the gears to higher rpms... by time your mevi kicks in, shift next gear.
and low end loss will suck with auto.
u just answered your own question
Old Oct 10, 2005 | 12:01 PM
86maxima96's Avatar
I Broke OT
wow, you're on quite the roll today!
Old Oct 10, 2005 | 12:02 PM
bigtimber's Avatar
autos have fewer (and thus longer) gears so they can stay in that peak HP range above 5000 RPMs longer than a manual
Old Oct 10, 2005 | 12:04 PM
MDeezy's Avatar
unless you get an ecu upgrade, you will get back most of that loss.
Old Oct 10, 2005 | 12:12 PM
bigtimber's Avatar
Not if you get a JWT ECU and shift "manually"...
Old Oct 10, 2005 | 12:19 PM
tuko's Avatar
will shifting "manually" harm the engine/tranny?
Old Oct 10, 2005 | 12:34 PM
|Bijan|'s Avatar
UCF Lexus
mmm hmmm
Old Oct 10, 2005 | 02:23 PM
deezo's Avatar
Do you even have a MEVI? If your car is in tune, it will feel very close to stock. If anyone doesn't believe it, they can drive my car and I don't have my TS ECU anymore.
Old Nov 9, 2005 | 10:15 AM
GStrength's Avatar
I just found this old thread, so can anyone just become decisive and tell me weather the mevi intake manifold will be worth putting on my automatic maxima? Cause I'm about a week from ordering it. I really need to know i dont wanna spend close to 500 dollars for no reason.
Old Nov 9, 2005 | 10:16 AM
NmexMAX's Avatar
dot dot dot ...
Yes it is.... search more
Old Nov 9, 2005 | 10:27 AM
GodFather's Avatar
Made in Taiwan
mevi is good for high ends in both auto and 5 speed, no doubt. however..
if you plan to drag race with the mevi on, you will need to do more mods soon because mevi kills your torque by bunch. i was so pssed with the torque loss at first, so i went on and did the rest of my mod list after that and now it feels great.
if you plan to just roll with mevi, it won't make a big difference to have lost that low end torque, but your high ends driving will be very appreciable. this is a plus for rolling with mevi on the highways, both auto and maxima. then you will also hear from a million of us saying over and over again: If you get mevi, make sure to upgrade your ecu to get most of that torque back; preferrably, get the jwt's 7200 redline ecu so you can ride on the elongated mevi powerband.
Old Nov 9, 2005 | 11:11 AM
zander's Avatar
My rpm switch broke shortly after I got it so the mevi didn't open up more then once. But the time it did it was freakin sweet. I put the old manifold back on and only noticed surges that the mevi eliminates. Mevi creates a much smoother, quieter sound. I'm auto by the way and I liked it, just need a new rpm switch.
Old Nov 9, 2005 | 12:45 PM
risingmist's Avatar
get a 00vi, and call it a day.
a little more intense to install but you dont loose as much of the mid range power, and you can get one for 500.
Old Nov 9, 2005 | 12:48 PM
NmexMAX's Avatar
dot dot dot ...
wher can i gt a rite up uv 1 uv these?
Old Nov 9, 2005 | 01:10 PM
greengrass215's Avatar
hey just want to ask, do you actully need to install a relay on the rpm switch? i didn't put one in. but it works fine, I just install it not to long ago, about a month now.
Old Nov 9, 2005 | 01:18 PM
NmexMAX's Avatar
dot dot dot ...
No relay on mine
Old Nov 9, 2005 | 01:32 PM
GStrength's Avatar
So are you saying that with the mevi intake manifold you loose the the jump edge in the beginning of a drag race, unless you have mods installed.
Old Nov 9, 2005 | 01:37 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread....light=MEVI+FAQ Taken from the stickys
http://forums.maxima.org/showthread....&page=12&pp=30
Posts #'s 338, 341, 347, 352 are the reasons I was telling you not to do as you were doing, so there's the answer to your email.
Old Nov 9, 2005 | 01:46 PM
GodFather's Avatar
Made in Taiwan
that's right, right after the mevi install, the jump is still there, but not as strong as with the stock intake manifold. however: after modifications, you'll be able to compensate it greatly especially if you have a 5 speed. anyways, take off is the key to the qm drag race, but after take off, it's all mevi...
Old Nov 9, 2005 | 01:48 PM
NmexMAX's Avatar
dot dot dot ...
Only one case where someone did NOT lose any low end w/MEVI.
Old Nov 9, 2005 | 02:00 PM
Chapman99SE's Avatar
out of the blue question realting to mevis, JWTs, and autos, i dont even have an auto so just wondering
but is there anyway to chage the shift points up on the transmission to reflect the new redline with the JWT ecu?
Old Nov 9, 2005 | 02:04 PM
NmexMAX's Avatar
dot dot dot ...
By manually shifting it ...
Old Nov 9, 2005 | 02:15 PM
GodFather's Avatar
Made in Taiwan
on my 5 speed stock setup with mevi, i remember going redline on first gear, then drops back to about 4700 rpms to catch 2nd gear. then 4600 catching 3rd.
after i had mevi coupled with the jwt's 7200 redline ecu. my shifts would catch around 5000-5100 right on. after i complete my mod list, shifts were never caught up below 5200, governing my driving on the mevi's powerband. this was good until my clutch started slipping like a btch... rpm's would be higher but with stick-slips.
Old Nov 9, 2005 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
I think he was referring to autos
Old Nov 9, 2005 | 03:24 PM
MaximaSpd85's Avatar
Zach?? someone else? I personally talked to Sean05 and he said that he did not feel any low end loss wutsoever. No dyno to prove, but maybe it was such a minimal loss that it just felt the same to him.
Old Nov 9, 2005 | 03:25 PM
NmexMAX's Avatar
dot dot dot ...
Unless he has a dyno, good is a "feeling"? Yes zack342
Old Nov 9, 2005 | 03:31 PM
Hey wen you're in your ride, "feeling" is all that matters rite? As long as it feels good
Old Nov 9, 2005 | 03:33 PM
NmexMAX's Avatar
dot dot dot ...
Ok .... ... IMO, Actual #'s are better.
People in civics feel good when tehy hit the "sweet spot" :
Old Nov 9, 2005 | 03:37 PM
So Zach had no loss, but wasnt that with the stock ecu? i remember he was having problems with jwt, but cant remember if that dyno was with it. Assuming that dyno was with the stock ecu, could we say that he had a lowend gain by adding the mevi?
Old Nov 9, 2005 | 03:39 PM
NmexMAX's Avatar
dot dot dot ...
.. explain yourself, that makes no sense He has bot w/ and w/o JWT.
Old Nov 9, 2005 | 03:45 PM
ahh, nevermind. I cant even explain myself.
Old Nov 9, 2005 | 03:47 PM
NmexMAX's Avatar
dot dot dot ...
JWT ECu did nothing for him ... Check the thread... something happened after 6500 and the power went --->
Old Nov 9, 2005 | 05:44 PM
motocross416's Avatar
thats a hilarious smiliey.
ECU isn't necasary, I don't have one yet. But it would be nice, once the MEVI opens my car runs into the rev limiter really fast. Hopefully Greddy will get the timing advance and extended rev limit working for our cars on the EU
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
