Greddy Exhaust with Silencer...way a maxima should sound
I just put in my Greddy EVO with a silencer...OMG....car sounds amazing...nice deep mellow tone...not obnoxiously loud....definete recommendation....
I'll try to get some sound clips. A silencer is a metal piece that reduces the size of the exhaust tip suppressing the noise level. Some people believe that a silencer increase back pressure thus increase torque more than the normal gain. Its on a stock y-pipe at the moment but I will be upgrading shortly. It is not loud at all (low rumble, mellow deep sound on acceleration).. Puppet i'll try to post a clip asap...
Btw, with regards to backpressure, it will not increase torque:
http://www.magnaflow.com/05news/magazine/05sportc.asp
BACKPRESSURE = TORQUE?
An old hot-rodder's tall tale: Engines need some backpressure to work properly and make torque. That is not true. What engines need is low backpressure, but high exhaust stream velocity. A fast-moving but free-flowing gas column in the exhaust helps create a rarefaction or a negative pressure wave behind the exhaust valve as it opens. This vacuum helps scavenge the cylinder of exhaust gas faster and more thoroughly with less pumping losses. An exhaust pipe that is too big in diameter has low backpressure but lower velocity. The low velocity reduces the effectiveness of this scavenging effect, which has the greatest impact on low-end torque.
Low backpressure and high exhaust stream velocity can be achieved by running straight-through free-flowing mufflers and small pipe diameters. The only two exceptions to this are turbocharged engines and engines optimized for large amounts of nitrous oxide. Both of these devices vastly increase the exhaust gas volume and simply need larger pipes to get rid of it all.
Some stock mufflers and exhaust systems have up to 18psi of choking, power-robbing backpressure. In direct contrast, a well-designed, high-performance street exhaust system typically has about 2 to 6 psi of backpressure. For an interesting comparison, an un-muffled straight pipe on a real racecar usually has 1 to 3 psi of backpressure.
Where did you purchase the silencer?
Where did you get your silencer? I have an Evo2 (and after markey y-pipe & CAI), and while I like the sound 95% of the time, there are a few times I would like to quiet it down a little. I have never seen a silencer for Greddy brand mufflers...
Originally Posted by 03MajesticMax
What exactly is a silencer? Do you have the stock y pipe on? if so is it alot louder?
09maxshawn11
Aug 14, 2015 10:07 PM
Jcof88
Aug 3, 2015 10:43 PM
