PO745 and a harsh 1-2 shift? ('97)
Old Oct 22, 2005 | 10:53 AM
jvienneau's Avatar
My '97 Maxima just started shifting hard from first to second and set a code of PO745 which is something about line pressure. Anyone been here before? It has 157K on it, but she's been well maintained and the trans fluid has been changed several times.
Old Oct 22, 2005 | 11:13 AM
cefiro8701's Avatar
do u have the drop resitor mod?
Old Oct 22, 2005 | 04:11 PM
jvienneau's Avatar
No, but I just measured the resistor and it's open.
Old Oct 23, 2005 | 04:43 PM
djdirtyrice's Avatar
yes my max shifts hard from first to second, what to do\?
Old Oct 23, 2005 | 06:59 PM
jvienneau's Avatar
There's a resistor mounted in an aluminum housing bolted to the driver's side strut housing. Measure it with a multimeter. Should be ~12 ohms if it's good.
Old Oct 24, 2005 | 07:14 AM
ti2tmax's Avatar
Has his VINs memorized
pressure control selenoid A circuit malfunction
Old Nov 1, 2005 | 12:47 AM
rubo1968's Avatar
My max does same thing it shift 1 to 2 gears when rpm reaches 4500. is if same problem? what should i do?
Old Nov 1, 2005 | 10:49 AM
GodStrength
can you get a shift kit for a 97 nissan maxima?
Old Nov 1, 2005 | 10:59 AM
f550maranello2's Avatar
There's ur problem.. make sure one more time that the ohm meter shows overload or infinity... if it does just replace the resistor and you should be good because the line pressure solenoid relies on the resistor... if it infact shows 12 ohms you probably need a new line pressure solenoid...
Old Nov 2, 2005 | 09:34 PM
eyesack killa's Avatar
my 95 max shifts hard 1-2 ONLY when it's cold (engine temp)... anyone know why? i'd like to check it out with an ohmeter, but how do you use one? sorry im a noob plz i hope this isn't hijacking
Old Nov 2, 2005 | 09:40 PM
Nissan 6's Avatar
Didnt you get banned for hijacking threads? Your still doing it......do you need another ban to learn your lesson?
Old May 21, 2009 | 03:18 PM
rneedles's Avatar
PO745 code
I would appreciate any advice from the readers. I have a 1998 Nissan Maxima GLE and the check engine light is on and the Code PO745 (Pressure Control Selenoid "A" Circuit Malfunction) is active. Could someone please explain where this is located and where to order this part from. Any other advice will be greatly appreciated. Thanks.
Old May 11, 2011 | 10:54 AM
Jowwe's Avatar
I had same problem. Checked drop resistor, mounted on DS shock tower, behind airbox. Had infinite resistance. Replaced it and problem fix immediately.
Old May 11, 2011 | 11:54 AM
eddie982's Avatar
Dude's been a member since 05' with 3,594 posts and he's a noob!
2 year necrobumpage! But it is valuable input, I've seen a few posts with same issue, damn resistor.
Old May 11, 2011 | 12:02 PM
Jowwe's Avatar
I posted mostly for noobs like myself searching, let em know it worked for me. Dealer tried to sell me $500 solenoid pack, I told em just the resistor. The guy said he never saw one go bad...guess he didn't work there long.
Old May 11, 2011 | 12:06 PM
eddie982's Avatar
Were you experiencing hard shifting form 1- 2 only or all gears?
Old May 11, 2011 | 12:26 PM
Jowwe's Avatar
Mine was only in 1-2. I know the resistor should affect all gears but I gave it a try and it worked.
Old May 11, 2011 | 12:32 PM
eddie982's Avatar
Thanks, good to know. I'm having this **** in all gears, gotta get a used replacement.
Old May 11, 2011 | 12:43 PM
Jowwe's Avatar
My symptoms were harsh 1-2 shift, blinking OD light and fault for open circuit in shift circuit A.
Old May 11, 2011 | 12:50 PM
eddie982's Avatar
how much did you pay for the new drop resistor from the stealership?
Old May 11, 2011 | 12:56 PM
Jowwe's Avatar
$40
Old May 11, 2011 | 12:58 PM
eddie982's Avatar
Not too bad, I thought i saw it for $50 + at courtesy.
Old May 11, 2011 | 01:13 PM
luke95gxe's Avatar
classifieds i have one for sale and i think maxima joe has one for sale
Old May 11, 2011 | 01:16 PM
cashoit's Avatar
us MT guys dont worry bout no DR mod hehe
lolz
Old May 11, 2011 | 01:17 PM
luke95gxe's Avatar
lolz
sure dont mine came off my 98 when it got totaled love the option to change my own gears
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
