Sponsored by:
Sponsored by: CARiD
Possible problem?
Old Nov 2, 2005 | 06:38 AM
i30ish's Avatar
Possible problem?
Don’t know if it’s a problem, but it sure annoys me. Since I got the car almost 4 months ago, I’ve noticed that around 2000 rpm in 2nd or 3d gear a sort of rattling noise starts coming from the engine. It’s not all the time, I think it happens when I drive for longer periods of time. No shaking of any sort(engine/transmission), just the noise. All I have to do to get it to stop is to let off teh gas pedal and then “floor” the it to the increase the rpm’s to 2500-3000+. The car picks up speed and noise disappears. Transmission shifts fine. While in idling engine sounds good. Under hard acceleration from a stop the noise dos not appear. What could it be?
Old Nov 2, 2005 | 07:45 AM
Stephen Max's Avatar
Timing chain tensioner gone bad?
Old Nov 2, 2005 | 08:12 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
Or weak oil pump, i had one i replaced all timing components and still rattled. If you need it fixed and wanna drive too PA hit me up.
Old Nov 2, 2005 | 08:43 PM
i30ish's Avatar
thanks, timing chain tensioner sounds as a possibility ...........i know it's a major thing to change timing belt, but to check the tensioner on the chain how much time and $$ am i looking at? how does oil pump make up noises like that? Sorry i'm not a mechanic.... Others have suggested transmission problems
Old Nov 3, 2005 | 04:56 AM
The tensioner works off of oil pressure, so if pressure is low, the tensioner will exert less force on the timing chain. This causes the chain to rattle.
Old Nov 3, 2005 | 11:58 AM
i30ish's Avatar
is this something that needs to me immediately fixed? is there a way i can check for il pressure myself or i have to go to a mechanic?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
